#19 |
Lurker supreme!
Hey rw... just saw the pics in your garage... look good! I think I prefer the 45 profile tire with the 16's than the 50 profile. Just my preference. Now you have to get the car lowered!!
2006 Red Blitzed RS 5-door |
#20 |
#21 |
Rwseattle
Drives: 2007 Toyota Yaris (BASE) Join Date: Dec 2006
Thanks. I agree on the lowering springs but, I'm not sure about the type of spring TRD or Tanabe DF210.
TRD 1.0 f and r (factory warranty) DF 210 Tanabe front 1.6 and rear 1.8 NF 210 Tanabe front 1.0 and rear 1.3 (I think these will work best) I Like a more level look. The back needs to come down. What do you guys think? Thanks Ron |
#22 |
Break'em off some.
I recommend Springtech. 1.7 inch drop all around. The DFs are too low in the rear for my taste. Check out my garage pics if you like.
#23 |
Rwseattle
Yes, your car looks great with the Springtech 1.7. You do have the 205/50/16 and my car has the 205/45/16. I'm going towards the Tanabe front 1.0 rear 1.3 or your Springtech 1.7 in lowering springs. How's the ride with the Springtech springs? Thanks for your feedback.
#24 | |
Break'em off some.
For me it was between the TRD springs and the Springtech. The TRDs just don't look quite low enough on cars with 15s or 16s. They look alot better on cars with 17s or 18s. I was pleasantly suprised with the ride after I installed the springs. The car rides great. My tires slightly rub the inner fenderwells at high speed on large bumps. You probably wont have that issue because your 45 series tires are a little shorter. I will be installing the TRD shocks/struts soon and that will solve my slight rubbing issue. I got my springs on Ebay for $130. I was local so I picked them up. |
#25 |
Mine has the NF210's. If you check my garage at least you'll get a visual. Measured drop was just as advertised. They ride great (much more firm than stock but not at all harsh), but, they look almost like a factory sport suspension. I think a little more drop looks better but obviously it wll be much stiffer. Mines a daily driver (100 miles per day).
#26 |
Lurker supreme!
Interesting...!! I have the TRD springs... good to know! Thanks.
#27 |
Break'em off some.
#28 |
Rwseattle
Did you install the spring or had a local tires center help you? I'm thinking about installing the spring with the DIY info. I will keep you posted.
#29 | |
Break'em off some.
Its easy to do yourself. The diy info was helpful, but I saw no need to remove all the cowl stuff and the wipers in the front. Just make sure you have an offset 17mm box end and a 6 mm allen key and you will be good to go in the front. The back is very easy. Air tools will help, removing and installing the strut shaft nut to remove the spring, but aren't necessary. |
#30 |
Rwseattle
That's great. I will order the springs soon and install them. I will post pix right after the installation. Thank you for your feedback.
| tanabe nf210 vs. TRD lowering springs?? | static808 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 37 | 01-23-2012 11:00 PM |
| Lowering Springs - Questions ~ | jaspie | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 16 | 01-10-2007 08:21 AM |
| TRD lowering springs' and/or shocks' Ride Quality?? | static808 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 28 | 08-29-2006 12:42 PM |
| Will putting new lowering springs damage original shock absorbers in the long run? | Joel Leong | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 06-07-2006 08:30 AM |
