Old 11-26-2010, 06:30 PM   #1
yarismadness
Drives: Yaris 2007 hatchback 5 doors
Reusing the chutch switch to turn off the cruise
Guys,
I had I idea, and i need your opinion before trying it.
The yellow wire on the clutch switch that blocks the start (i am talking about the one on the bottom, not the additional we should add to stop the cruise), has normally (when released) 12V, high impedance (my guess is a pull up resistor inside the ECU). when pressed (the clutch needs to go to the bottom), that line goes near 0V (pulled down by the starter relay coil).
What if we sense that in order to stop the cruise? For example, a mosfet transistor will do the job perfectly.
The problem: the cruise will disable ONLY if the clutch is COMPLETELY pressed. What will happen during the clutch travel?
Cheers!
yarismadness is offline   Reply With Quote
Old 11-26-2010, 07:59 PM   #2
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
Originally Posted by yarismadness View Post
Guys,
Cheers!
I'm not an expert but I'm pretty sure the engine will rev up. disengaging the clutch will slow the car, which the ecu will see and will give it more gas to try to maintain speed. most of the time you do not floor the clutch (which would be required for this to disengage the cruise). I personally would not like this solution...
DIY Cruise Control on 07-08 Yaris (step by step) Vince87 DIY / Maintenance / Service 431 12-28-2020 01:37 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
