Old 11-29-2010, 05:02 PM   #1
yarisdude447
Drives: 2009 Yaris Hatchback
Yeah, definitely bring it back to where you had the work done. It sounds like maybe there's a loose bolt or nut somewhere, because it can't be something like suspension... which they shouldn't touch when doing a clutch install. Pretty safe to assume that if it was fine before the clutch install, and started doing this after the clutch install... you can probably bet that it's the clutch work that's at fault here.
yarisdude447 is offline   Reply With Quote
