Rwseattle
Drives: 2007 Toyota Yaris (BASE) Join Date: Dec 2006
Did you install the spring or had a local tires center help you? I'm thinking about installing the spring with the DIY info. I will keep you posted.
#2 | |
Break'em off some.
Drives: 07 Yaris LB, 04 Cobra Join Date: Jan 2007
Its easy to do yourself. The diy info was helpful, but I saw no need to remove all the cowl stuff and the wipers in the front. Just make sure you have an offset 17mm box end and a 6 mm allen key and you will be good to go in the front. The back is very easy. Air tools will help, removing and installing the strut shaft nut to remove the spring, but aren't necessary. |
Rwseattle
That's great. I will order the springs soon and install them. I will post pix right after the installation. Thank you for your feedback.
| tanabe nf210 vs. TRD lowering springs?? | static808 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 37 | 01-23-2012 11:00 PM |
| Lowering Springs - Questions ~ | jaspie | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 16 | 01-10-2007 08:21 AM |
| TRD lowering springs' and/or shocks' Ride Quality?? | static808 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 28 | 08-29-2006 12:42 PM |
| Will putting new lowering springs damage original shock absorbers in the long run? | Joel Leong | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 06-07-2006 08:30 AM |
| Factory Lowering Springs + MAX Wheels? What are the options? | bigsky2 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 05-24-2006 08:10 PM |
