Old 11-30-2010, 04:14 PM   #1
severous01
i hope the kit comes with a proportioning valve...if not, get any prop valve off a yota with discs...or one of the xb/xa's
Old 11-30-2010, 09:07 PM   #2
auxmike
auxmike's Avatar
Don't all cars have the valve regardless??
Old 12-01-2010, 08:24 AM   #3
xbgod
Drives: "Burning It Down GTX2860RS XB"
Depending on your application that will differ.
A proportioning valve will allow you to adust pressure on that line only. It will not divert the pressure from the front to rear or vise-versa. So be mindfull if you put one on. It works on that line only to adust pressure.
A residual valve is what is usually on a drum set-up. This allows the line to hold pressure on the springs for the drums. these usually come in 2lb or 10lb valves.
Most master cylinders are a 70/30 split. This means 70% goes to the front and 30 to the rear. This would be typical of a stock set-up. You can go to an aftermarket one for racing which can be a 60/40 split or even to a 50/50 split. Wilwood Engineering sells these.
However for what your doing none of this should be necsessary. Unless you put some huge 6 piston caliper in the rear.
I converted my drum to disc in my XB and left the M/C and all stock valving alone. I have no issues. No brake fade, no spongey pedal. All works fine.
If you need to get more technical PM me. I've done drum to disc conversions for racing for 11 years.
XBG
xbgod is offline   Reply With Quote
Old 12-02-2010, 09:57 PM   #4
Evangelion335
Evangelion335's Avatar
Drives: Soon
Thanks guys, i dont want to get rims and then have nasty drums lurking in the back.
Evangelion335 is offline   Reply With Quote
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 05:02 PM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 10:11 AM
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 07:20 PM
rear drums the same on '01? cali yaris Performance Modifications 7 11-21-2008 10:46 AM
