Old 12-02-2010, 08:10 AM   #1
rakhan01
Drives: Toyota Vitz 2004
well. it could be the case.
I went to near by toyota service center. They could not seem to find the solution. They connected the obd II reader but it showed everything ok. Engine and ecu ok , airbag and abs ok as well. Even if it's the led, the obd should detect the problem which is not the case. What do you suggest?
they also said the fuses and wires are ok.
rakhan01 is offline   Reply With Quote
Old 12-02-2010, 08:34 AM   #2
The ECM for that vintage may not actually detect a bad LED/Bulb, so that's where I would check first. The EWD for your 2004 shows that the feed from the ECM to that indicator is on Pin 8 of the smaller connector. You can measure the voltage on that pin to ground to verify that the ECM is outputting to it.
It is definitely not a fuse issue, as many other indicators would be out.
Old 12-02-2010, 09:05 AM   #3
rakhan01
this is the thing i need to tell the electrician as i haven't done it before. Apart from it, do you think of anything else which could be the problem. Please list the feared problems so i could tell my electrician to check.
Old 12-02-2010, 09:27 AM   #4
I am fairly certain that it's a bulb rather than LED and that the bulb is burned out. I just noticed in the circuit diagram of the inside of the meter, that all of the indicators, except for water temp have the symbol for a bulb, rather than LED. Just the water temp indicator is drawn as an LED.
electrical problem with car need help badly!! Adriaan DIY / Maintenance / Service 20 05-07-2010 12:40 AM
Custom Lftback - Photo-Scavenger Hunt custom Lftback Photo-Video-Media Gallery 2 03-01-2009 11:12 PM
Photo Scavenger Hunt Ideas Thread Black Yaris Photo-Video-Media Gallery 41 02-28-2009 08:54 PM
