Old 12-03-2010, 11:49 PM   #1
detroiter
detroiter's Avatar
Best replacement tire size for stock rims?
Kind of unsure what tire size to get because some say with the stock 185/60's that the speedometer is incorrect, but other sizes show to be incorrect as well. What would be the best replacement size for the stock 15" rims? I'm running Tein springs.
Old 12-04-2010, 10:57 AM   #2
detroiter
detroiter's Avatar
bump
Old 12-04-2010, 12:40 PM   #3
Kal-El
Kal-El's Avatar
I'd be surprised if the speedo was off with 185/60's since that is what Toyota puts on stock. Speedometers are factory set based on stock diameters.
Either way, the speedo change is negligible with only slight size variations. It's not something to concern yourself with.
I personally prefer 195/60's. They offer a fuller look that slightly extends beyond the wheel cover. The 185's look too thin and undersized IMO with the wheel covers protruding beyond them - not a great look. I've clocked my speed with a GPS and the speedo was accurate even with 195's. Plus, performance/stability naturally improves with the wider tread.
EDIT: Forgot you said you were lowered. In this case, perhaps a 195/55 would be a better choice since you have less wheel gap.
Old 12-04-2010, 11:11 PM   #4
kimona
kimona's Avatar
Drives: 2014 White VITZ
My speedo was off with the stock 185/60/15's, but is dead on with 205/50/16's.
With Tein springs, I would recommend 205/50/15's.
Old 12-04-2010, 11:11 PM   #5
detroiter
detroiter's Avatar
Well the 14" came stock in Canada as far as I know and there's no changes in the speedo setting between our 15" Yarii's and Canadas 14" ones.
So what would be the better choice then..195/55 or a 205/50?
Are they going to bulge out too much since the rims are only 5.5?
And how about sidewall flex, will that be a problem since they will stick
out more?
Old 12-05-2010, 10:07 AM   #6
Kal-El
Kal-El's Avatar
out more?
The 14"s come with 65's to adjust for the overall diameter.
As far as tire flex, I wouldn't worry about it with 195 or 205's. Tire flex is due more to sidewall height than width. Really, you'll have more grip and stability in the corners with these wider options.
Old 12-04-2010, 11:29 PM   #7
kimona
kimona's Avatar
205's will fit safely on 5.5" rim.
Old 12-05-2010, 06:49 AM   #8
nemelek
DWEED
nemelek's Avatar
Why don't test your speedomoter? Use the highway mile markes and compare the difference for 10 miles between the actual miles and your odometer. Assuming the speedometer and the odometer are in sync, you should know how accurate your car is. My stock set up is very accurate.
Old 12-05-2010, 11:19 PM   #9
Uber_Otter
Uber_Otter's Avatar
Drives: Black XA not yaris but close
Im going back to the 185/60 15s, I run stock steelies. I had replaced all four with 195/65 15s and it was bad. Mainly the 65 part, way too much sidewall lots of flex. The increased overall diameter\weight means your just pissing torque away too. It was noticable. The guy at discount tire company suggested them, i said okay, now I know better. Wider is ok, taller's not. I'll go wider when I get some lighter rims to make up the difference in unsprung wieght.
I order tires from tiresonline.com and install them myself with a harbor frieght tire changer and bubble balancer. First one was a beating, now it takes about 10 min a tire.
Uber_Otter is offline   Reply With Quote
Old 12-06-2010, 01:13 AM   #10
Kal-El
Kal-El's Avatar
I can't believe he sold you 195/65/15's for a Yaris. More proof to never let these morons make decisions for you. Tire shops are known for selling stuff that just needs to be unloaded from inventory. Always do your own research and decide on a tire/size before going into a store.
However, you don't need to go back to 185's. 195's are very good, just keep the aspect ratio to 60 or below.
Old 12-08-2010, 03:01 PM   #11
detroiter
detroiter's Avatar
Thanks for the help guys. So I'm leaning towards 195-55's. Would the 205-50-15
give me any trouble since I'm riding low with the Teins?
Old 12-08-2010, 04:57 PM   #12
33OH
Drives: '08 Yaris
^ Nope. And I'd go for 205/50's unless you're running these in the snow. Then I'd recommend the 185's.
Old 12-09-2010, 12:19 AM   #13
detroiter
detroiter's Avatar
Yeah i'm going to be running these in the snow. Not really feeling the 185s though, they charge alot more than they do for 195's, atleast here they do anyway
Old 12-10-2010, 04:00 PM   #14
hatchbackkid82
Drives: .
im running 195/55/15 but i have my car lowered
Old 12-10-2010, 04:27 PM   #15
33OH
Drives: '08 Yaris
I've ran four different sizes on 15's so far (205/50, 195/55, 195/50, 185/60) and I while I loved the 205/50 and 195/55 or 50's in the summer, they sucked in any sort of snow accumulation.
But if you're going for price only, 195/50's are usually cheaper than 195/55's since it's a common size for the Honda guys.
what tire size fits best for 15x6 rims? savister Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 04-26-2010 08:37 PM
Tire Size and FE question GMKing Fuel Economy Forum 8 09-01-2009 09:20 PM
screw more psi in the tires. thebarber Fuel Economy Forum 43 05-04-2009 04:46 PM
The Tire inflation debate... Tankota General Yaris / Vitz Discussion 20 06-01-2006 07:09 PM
