Old 12-04-2010, 11:11 PM   #1
detroiter
detroiter's Avatar
Well the 14" came stock in Canada as far as I know and there's no changes in the speedo setting between our 15" Yarii's and Canadas 14" ones.
So what would be the better choice then..195/55 or a 205/50?
Are they going to bulge out too much since the rims are only 5.5?
And how about sidewall flex, will that be a problem since they will stick
out more?
Old 12-05-2010, 10:07 AM   #2
Kal-El
Kal-El's Avatar
out more?
The 14"s come with 65's to adjust for the overall diameter.
As far as tire flex, I wouldn't worry about it with 195 or 205's. Tire flex is due more to sidewall height than width. Really, you'll have more grip and stability in the corners with these wider options.
what tire size fits best for 15x6 rims? savister Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 04-26-2010 08:37 PM
Tire Size and FE question GMKing Fuel Economy Forum 8 09-01-2009 09:20 PM
screw more psi in the tires. thebarber Fuel Economy Forum 43 05-04-2009 04:46 PM
The Tire inflation debate... Tankota General Yaris / Vitz Discussion 20 06-01-2006 07:09 PM
