Old 12-08-2010, 01:10 PM   #1
Judas Iscariot
Drives: 2008 Yaris HB
Agreed, i wouldn't think of using a larger fuse... and i did check to see if the bulbs are good, i can see both hi\low filaments, they are intact and the bulbs were less than a week old at time of origional post.
Thanks for the replys CT, but you were saying something about which wires to follow... if pictures will help i can have them on here tomorrow.
Judas Iscariot is offline   Reply With Quote
Old 12-08-2010, 02:18 PM   #2
Pictures would definitely help. The wiring harness to the right side headlight is housed in wire loom for all but a few inches on either end, so if the problem is with the OEM wiring it is almost definitely on one end or the other of the wire from the fuse panel to the bulb. The additional wiring, that you mentioned, is more likely where the problem lies, so pictures of that would help.
Old 12-09-2010, 12:11 PM   #3
Judas Iscariot
Thx CT, i left my camera at home, so i'll take the pictures tonight and hopefully post them tomorrow.... i hate not having headlights!
Old 12-24-2010, 02:56 PM   #4
Judas Iscariot
Ok. So I am still battling this problem. The headlights come on now. But the driver side light is acting funny, both of the filaments are coming on and they are dim in comparison to the other one. Which works correctly. I don't know how it got to the state it's inn now. But at least I can drive at night. Any more ideas CT? Thanks again in advance
Old 12-24-2010, 03:25 PM   #5
The H-LP/AMT Relay in the small relay box, on the passenger side, under the hood, may be sticking. You can try putting the HTR relay in its place to see if it cures the problem. The HTR relay is the center one at the bottom of the under dash fuse panel. The HTR relay is the same shape as the H-LP/AMT relay, but may have a different color shell. The two are identical though in function, so they can be swapped.
DIY - Headlights off with the Ignition Switch CTScott DIY / Maintenance / Service 46 11-03-2018 08:42 PM
aftermarket headlights be_ha Cosmetic Modifications (Exterior/Interior) 0 10-03-2010 03:06 AM
Best Aftermarket Headlights MadMax Cosmetic Modifications (Exterior/Interior) 3 06-04-2009 06:50 PM
Angel Eyes headlights Danish Yaris Cosmetic Modifications (Exterior/Interior) 9 02-13-2009 09:15 AM
JDM headlights yrsdrgn Cosmetic Modifications (Exterior/Interior) 6 02-13-2007 10:52 AM
