Old 12-09-2010, 06:42 PM   #1
bieniman
bieniman's Avatar
Drives: vitz rs 1500 2001
I finally got a mechanic who will did a diagnoses for me, when he came the first time he did a precheck at the diagnostic adapter, he found out that the check engine lamp did not work at all(thats the way he does it, and with a paper clip, by looking at the number of times the check engine light blinks, he knows what the error codes are!!!Amazing!!!). Does anyone know how to replace the check engine lamp?
Also, when in idle, is the engine supposed to react when you pull out the connector from the OCV? Because it did not react, so we shut off the engine and inspected the OCV, it did not react when we switch the ignition to on and off, he checked it at work and its ok. He says it might be a faulty wire. We'll check that this weekend.
thanks R2D2, well I started the engine very briefly when the OCV was not installed yet, it squirted oil every where trough the hole, shut the engine off immediately. Now we know that the pump is creating pressure, so it is not the filter or pan blockage (maybe?).
Bluevitz-rs, I'll check the pan tomorrow.
Does anyone know where to find the wiring diagrams for the 1NZ-FE??I need it this weekend!!!!
Thanks guys, I'll keep you posted
bieniman is offline   Reply With Quote
Old 12-09-2010, 06:54 PM   #2
First off, the Yaris (even your 1st gen one) doesn't support the DTC display by jumpering a pin on the DLC3 connector (like some other vehicles do), so your mechanic must use an ODBII code reader to read the DTCs.
I have the EWDs for your 2001. Shoot me a PM with your email address and I'll get them to you.
Tags
engine, low pressure, noise, oil, oil lamp
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 06:41 PM
Transmission Oil for Yaris 1st Gen adigilani DIY / Maintenance / Service 3 10-23-2011 02:48 PM
My first noise bst82551 DIY / Maintenance / Service 9 08-13-2010 09:05 AM
1NZ-FE tuned by Phoenix-r sujonol78 Performance Modifications 50 02-08-2010 01:34 PM
Anyone running Royal Purple? firebird1999us DIY / Maintenance / Service 80 02-27-2009 10:30 PM
