#1747 |
![]() ![]() ![]() Drives: 07 Sedan - 5 Speed Manual Join Date: May 2006
Latest fill up
My best so far to date:
Distance:475.4 mi. Fuel Used:10.926 MPG: 43.51 |
#1748 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris sedan auto / Fit auto Join Date: Oct 2009
2010 3 door w/ auto : 42.17 m.p.g. ( 87mis. / 2.063 gals. : 1 click of nozzle ) , E.M. ( Eco-Meter ) : 42 ; 2 people , many hills , 35 p.s.i. , VALERO 87 , avg. speed :47 m.p.h. , 42 degrees , Winds : N.E. 10 > 20 , dry roads , PENNZOIL Yellow Bottle ( conventional ) 5w-30 ( S.N. , GF-5 ) , and 25% Cty. / 75% Hwy.. Car has 12,350+ mis..
#1749 |
![]() ![]() Drives: Yaris sedan Join Date: Jun 2010
95% of in town driving, highway trips are around 4 miles.
35.3MPG!!! I should get above 40s if i drive mostly highway. |
#1750 |
![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Jun 2006
I get between 38 and 42 mpg on my daily interstate commutes, I get closer to 38 mpg if Im driving 70+ and 42 if I drive like 63 mpg in cruise. here in Kentucky I-75. Keep the RPM below 3,000 and the car does really well. I like to run at a speed of 2800-2850 on the interstate in my AT.
#1751 | |
![]() ![]() ![]() Drives: 07 Yaris Sedan, Auto Join Date: Jun 2010
#1752 |
2008 sedan w/ auto : 41.045 m.p.g. ( 376.8 mis. / 9.18 gals. ) , VALERO 89 ( winter blend ) w/ TECHRON , 2 bars left . Gas mileage seems to be fine since the head cylinder gasket replacement .
#1753 |
Gallons to fill up: 10.83 gallons
Miles: 502.5 MPG: 46.39 My best MPG's so far & my 1st tank @500 miles or better. ![]()
#1754 | |
"LibertyRides!"
Drives: 2010 Yaris 3Dr LB | 2020 Stang Join Date: Mar 2010
...And Southern Cal to boot! Cheers!
~ Mark ~ 2010 Yaris 3-Dr Liftback, 5-Speed Manual, P185/60R 15, Bayou Blue Pearl I Love my YARIS Most miles Tank: 538 tank/10.148 gal = 53.015 MPG / Most MPG: 54.95 MPG (ethanol) 425 tank/7.73 gal "The evils of government are directly proportional to the tolerance of the people." -- Frank Kent |
#1755 |
Thank you STC
#1756 |
![]() Drives: 09 LB, 3 door, auto Join Date: May 2009
Nice, how fast do you normally drive ?
#1757 |
@ petyanca, I was in the slow lane and doing between 55-65, keeping with the flow of traffic.
#1758 |
![]() Drives: 2010 Toyota Yaris 3 door Join Date: Mar 2010
I average 36 MPG driving city and interstate with an automatic transmission. The best was 39 MPG and the worst was 31 MPG. I drive pretty hard too. I like the gas mileage. I think it is pretty good and the car has some zoom in it.
#1759 |
![]() ![]() ![]() Drives: Toyota Yaris 1.3 vvti cvt Join Date: May 2007
My Yaris diesel did 50 MPG, fully loaded, a/c on, lights on and normal driving.
#1760 |
Two Wheeled Fiend
Drives: 08 Yaris 2D Lftback 5-speed Join Date: Feb 2011
Getting mid to high 30's all winter... We've had a warm spell this last week though and I filled up with 6.12 gallons of fuel and went 296.8 miles, it worked out to 48.49mpg. Best Tank I've had thus far! I drive at 50-55mph and its all highway. Run full Synthetic oil and never use the brake pedal (engine brake everytime possible). My shoe box is giving my motorcycles a run for their money!
![]() 2008 Suzuki B-King 2001 Yamaha FZ1 (2005 motor swap) 1998 Suzuki Bandit 1200S 1983 Suzuki GR650 2008 Toyota Yaris 2DR HB (The Cage) |
#1761 |
![]() ![]() ![]() Drives: 2010 5 door hatch w/5 sp man. Join Date: Jan 2011
I've been getting low to mid 30s all winter, especially when I'm driving at 9 MPH behind people who have no right to drive in the snow. My Harley (Sportster XL 883 L) averages 50 MPH.
#1762 |
![]() ![]() Drives: '09 Yaris Sedan Join Date: Oct 2009
I am running 185/65-14 snows up front. With the longer warm up time and having to defrost the inside of the car, I'm down in the low 30s mpg. The more efficient the vehicle,the more effect the variables have. To stay in the big numbers takes a life style change. I have averaged just over 40 mpg for all the gas that has gone through the tank. 16 or 17 months so far.
doc |
#1763 |
![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris sedan Join Date: Jun 2007
When the 185s wear out, go narrower if available. Those wide tires actually work against you, not only does your fuel efficiency suffer, but the narrow tires work better in the snow because they cut through the snow deeper for better grip, and don't plow as much.
#1764 |
2008 auto sedan : 37.9 m.p.g. ; E.M.: 38.4 . 1 click of nozzle of winter blend 87 octane w/ 10% ethanol and 4 non studded COOPER Weathermaster ST-2 snow tires set at 35>36 p.s.i.. Overall temps of 30 . This includes some snow / ice covered roads as well . Not so bad . Can't wait for the warmer weather and summer blend of gas .
