What is needed to add a second keyless entry remote?
My Yaris came with 3 keys - 1 keyless entry and 2 regular. I am hoping to get a second keyless entry remote, or convert one of my 2 regular keys to a remote. I've found CTScott's guide on how to program them, but I'm not sure what to get in the first place!
I see some listings on eBay like this one which is a "remote key replacement shell" so I figure this isn't the only thing I need. But the same eBay store has these Transponder chip key which looks just like what I have now. Am I even looking in the right direction? Thanks & Cheers |
![]() ![]() Drives: 2007 Toyota Yaris Hatchback Join Date: May 2006
The replacement shell is just the shell and nothing else. That's what I just purchased to replace my mashed up buttons. It has no electronics. I believe you will need the transponder chip key.
I figured as much, but I hope there is someone here who knows what part I need to look for the remote.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 09 5dr LB, 2x 08 3dr LB Join Date: Oct 2008
Does you car have the engine immobilizer?
I believe so. I think that's required on all cars up in Canada unless I'm mistaken.
It's also worth noting that I already have one remote, but my wife uses it. |
The part number is: 89070-52850
Here's the first place that comes up doing a quick search: http://www.autotransponder.com/2009_..._entry_remotes |
What information should I ask about before bidding on something like this?
Part#, FCC ID, etc? http://cgi.ebay.ca/NEW-TOYOTA-CAMRY-...item3a5eb16296 |
#8 | |
Alright I'm back to wanting to do this.
I found a remote key with identical codes on the inside. Before I hit Buy It Now I want to confirm that getting it cut won't be a problem. Everything needed is already in the chip correct? Once it is cut and programmed using the guy it will work? |
#10 | |
Does this do what you are referring to? http://www.yarisworld.com/forums/sho...19&postcount=6
#12 | |
hm.. having trouble finding the section about the transponder key. I will have to spend some more time digging around before my key gets here!
EDIT: I found this http://www.toyotaownersclub.com/foru...howtopic=85266 (post #3). I will give it a shot. Last edited by teddy; 12-11-2010 at 11:21 PM. |
#14 |
Got my key - anybody know if it is possible to transfer my current key blade with the uncut key blade on the new remote key? It might be easier than trying to program the keys. I'm afraid of accidentally hitting the erase code to remove all my current keys!!
Edit: I don't think it's possible now. I see the transponder is in the key fob itself, not the blade. Last edited by teddy; 12-28-2010 at 10:35 PM. |
Thread Tools | |
Display Modes | |
Add remote to factory keyless. | imknotright | DIY / Maintenance / Service | 50 | 03-24-2018 12:10 PM |
Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 | CTScott | General Yaris / Vitz Discussion | 51 | 11-10-2012 01:32 PM |
Power door lock keyless entry and remote start | rizaydog | In Car Entertainment + Electronics (audio / video / alarm) | 10 | 07-20-2009 04:14 PM |
What is the FCC# for the keyless entry remote (3 Door)? | chingyeunglo | General Yaris / Vitz Discussion | 0 | 08-01-2007 09:25 PM |
Should I add remote key less entry? Options | YotaYarisUSA | General Yaris / Vitz Discussion | 13 | 05-02-2006 05:06 PM |
