Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 02-20-2011, 01:40 PM   #1
rosco
rosco's Avatar
Drives: YaRis ka!--Y?2011
Originally Posted by armando View Post
ako anytime, nalamangan nga ako doon sa inuman syang. wala man lng ang yaya!
rosco is offline   Reply With Quote
Old 02-20-2011, 02:14 PM   #2
jonimac
jonimac's Avatar
Drives: Yaris Sedan 2010
Send a message via Yahoo to jonimac
...Bro, huwag ka na magtampo... TRIAL lang yun, besides di rin preparado ang lahat, hayaan mo may kasunod yun tol.
...hoy magpaliwanag kayo!!!
jonimac is offline   Reply With Quote
Old 02-20-2011, 02:26 PM   #3
rosco
rosco's Avatar
okey dun daw sa khamsa khamsa..................softdrinks ??
Old 02-21-2011, 02:25 AM   #4
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
no comment
duke_afterdeath is offline   Reply With Quote
Old 02-21-2011, 01:15 AM   #5
jonimac
jonimac's Avatar
RMS POWER VS PEAK POWER
RMS Power refers to Root-Means-Square power. The formula for determining RMS power is 70.7 x Peak Power Rating. The RMS power rating is a measure of continuous power measured in watts and the higher the RMS power means the device is either able to provide or accept the specified power over a significant length of time without fail.
Most suppliers use the PEAK POWER ratings in their specifications. I would prefer not to recommend use of Peak Power when assessing the capabilities of a music product because Peak Power does not reflect a product’s capabilities under normal, every day use. It is simply a measure of how much power can be generated or handled for very short period of time. I believe speakers, subwoofers and amplifiers should be compared using the RMS power ratings to ensure the right product is chosen for the application in question. However, since most suppliers advertise peak power and since most consumers believe that larger numbers are better, some are forced to also advertise peak power.
For example, if a speaker has a RMS wattage rating of 100 watts and a connected amplifier has a RMS wattage rating of 100 watts, the speaker should theoretically, be a perfect match regarding power capabilities and a result in optimum performance from both products. While it is important to not be fooled by Peak Power, Peak to Peak or the erroneous numbers often made up by some suppliers, as long as you have accurate peak power numbers for both the speaker and the amp or receiver, you can still make an accurate comparison using the fornula above. While only true power, under everyday, realistic circumstances actually means anything, if one supplier advertises peak and another advertises RMS it becomes harder to make a comparison without an understanding of both.
Old 02-21-2011, 01:39 AM   #6
syntax
syntax's Avatar
pre nosebleed ako dito ahh...
Old 02-21-2011, 01:54 AM   #7
jonimac
jonimac's Avatar
aku din eh...
Simply... don't go for peak power, always look for RMS ratings (speakers & amplifiers) even sa mga Home Theater systems dyan.
Old 02-21-2011, 02:23 AM   #8
rosco
rosco's Avatar
aku din eh...
..isa kang gabay!
Old 02-21-2011, 02:32 AM   #9
duke_afterdeath
aku din eh...
Originally Posted by rosco View Post
..isa kang gabay!
sya ang daan?aliennnn...
Old 02-21-2011, 02:25 AM   #10
xtremist
xtremist's Avatar
Drives: yaris Y 2010 A.K.A. "sky"
thanks pre, punta agad ako ng clinic, daming dugo naubos sakin eh
Ciao !!!
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
xtremist is offline   Reply With Quote
Old 02-21-2011, 02:37 AM   #11
jonimac
jonimac's Avatar
Ayon sa... bersikulo... pahina... nasasaad dito...
BASA rosco!
Bwisettt!!!
Old 02-21-2011, 03:50 AM   #12
rosco
rosco's Avatar
Talking
BASA rosco!
Bwisettt!!!
Old 02-21-2011, 03:49 AM   #13
rosco
rosco's Avatar
lapit na uwian...lunch time.....makadaan nga muna sa quiapo...sa GALA theater.....or s CENTER stage....??hmmmmm...happy hour!!!!
Old 02-21-2011, 03:56 AM   #14
xtremist
xtremist's Avatar
@rosco, try mo din daan dun sa "phenomenal" sa likod ng Isetan Recto, happy hour dun starting 1pm (afternoon) till 5 am (the next morning)...
Ciao !!!
Old 02-21-2011, 04:06 AM   #15
rosco
rosco's Avatar
..oops..laman ka rin ng avenida ha.......nakaka miss din yang mga lugar sa manila...uso ang wise inn..ngayon SOGO na...may promo pa....kamagong sa pasay...mahal kita inn...sikat na sikat na..victoria secret ba yun??..anito psttt!!..katahimikan......ala ala ng kahapon...
Old 02-21-2011, 04:09 AM   #16
xtremist
xtremist's Avatar
wahahaha....correct, dti sikat sa avenida ang wise hotel pero tinalo na sila ng Sogo, dalawa pa ang branch, isa sa Avenida at isa sa Recto...hehehe, sa Sta. Mesa nagkalat din malapit sa PUP...wahahaha....
Ciao !!!
Old 02-21-2011, 04:14 AM   #17
rosco
rosco's Avatar
uy..may discovery bar dun ah.....malapit sa PUP.......PUP kayo jan bababa ng tulay pureza
Old 02-21-2011, 04:39 AM   #18
syntax
syntax's Avatar
@ xtremist at rosco... wahahahha dami alam ahh....
