Old 12-17-2010, 10:29 AM   #1
cdydjded
Drives: Yaris LB Turbo
Sounds like I convinced you that what you are doing wont work. Please forget all that has been said here & just install the 2zz manifold on the 1NZ like you planned. Prove me wrong just with that manifold. I want you to succeed. I want you to prove me wrong on your initial idea.
BTW you are aware that weapon R has a sheet metal manifold for the xB? It would be alot easier to modify that manifold to our car.....
cdydjded is offline   Reply With Quote
Old 12-17-2010, 10:34 AM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
His car's a first gen, so it would be bolt on.
Old 12-17-2010, 01:24 PM   #3
cdydjded
Good point, there you go, there's a low cost logical option : )
Old 12-17-2010, 04:56 PM   #4
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
Low cost? I just went to the weapon r website and the price is as high as $600 + $? shipping. The 2ZZ intake + throttle body + shipping was $300. Add a $50 job to make the adjustments + $80 intake flange.
For about $430 I get an intake with only welding on the flange, a 70mm throttle body which the weapon -r don't include and if I am not mistaken the runners of the 2ZZ are shorter which is better.
Also I can add $20 for polish and spray the intake as shiny as the weapon-r and that would be all.
I done my homework
Motor Longevity Pavel Olavich DIY / Maintenance / Service 10 03-17-2012 11:43 AM
cali yaris built motor cali yaris Performance Modifications 83 09-03-2009 11:08 PM
Fan motor noise... 500snakz General Yaris / Vitz Discussion 10 12-01-2008 02:43 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
Exchanging Motor on a Liftback 1.3 Lt weckjuan Performance Modifications 8 11-12-2006 10:58 AM
