Get a better quality charger. Poor quality chargers have little or no noise filtering.
I had the same issue the other day when i used a charger, it was one them cheap ones off Amazon, i have a sprint Samsung Intercept. i'll just be sure to charge the hell out my phone next time and only run Pandora till the battery's half full. Mine played for a good hour without draining the battery too bad. Lemme know if the expensive ones work better.
![]() ![]() Audio is under Construction Kenwood KDC-X794 Hifonics Zeus ZXI6.5C 6.5-Inch 2-Way Component Speaker System - AUTOTEK ATX65CX 6.5-Inch Hifonics BXi 1210D - Crunch PowerZone P1400.4 (2)12 inch Kicker CVR's - 0 gauge from battery to Distribution block - 4 Gauge Power/Grounds to amps - Duralast Yellow Top - Big 3 |
#3 | |
Thanks for the great suggestion hopefully this will be a cheap and easy fix! SWEET! |
iLuv Charger
| Tags |
| electrical, ground, static, stereo |
