Old 12-21-2010, 01:38 PM   #1
Jason@SportsCar
Originally Posted by jouna View Post
im trying to find a good heat wrap for my intake manifold because it gets preety hot. whats the best material? there are mainly exhaust heat wraps but i guess it'll do the job in the intake as well. are the titanium wraps better than the ceramic ones?
heres my intake manifold
Don't use a header wrap on a intake... Header wrap is designed to keep heat in, you need a product that keeps radiant heat out.
Something that provides an air-gap between the intake and outside heat sources will yield the best results.
These work well, but are not great to look at: http://www.designengineering.com/cat...l-tube-extreme
This works good, but not the best as it does not provide an air-gap, we have used this stuff on a number of cars: http://www.designengineering.com/cat...r/reflect-gold
We found this one works really well on systems that still use an air filter box, rather than just a tube with a filter. It will stick to anything, and puts an air-gap between the intake/box surface and the heat barrier: http://www.designengineering.com/cat...und-insulation
Old 12-21-2010, 04:18 PM   #2
jouna
jouna's Avatar
Drives: jdm yaris sedan
my intake burns to the touch after a drive do you think the tape from the tunnel shield would last? or would it peel off because of heat
vvti bregao!
jouna is offline   Reply With Quote
Old 12-21-2010, 04:26 PM   #3
Jason@SportsCar
Floor and Tunnel Shield was designed to withstand direct temperatures up to 1750°F. Because of it’s unique material, it is capable of insulating against unwanted road noise up to 50%.
Constructed utilizing an embossed 10 mil aluminum face bonded to a 1/8” composite fiberglass insulation, Floor and Tunnel Shield is backed with an aggressive adhesive that holds past 450°F. Only 3/16” thickness it requires minimal clearance and can be shaped and trimmed for a custom fit.
Floor and Tunnel Shield provides the optimal way to reflect heat away from vehicle components and perfect for protecting under hoods, firewalls, fuel cells, exterior areas such as transmission tunnel, floorpans and other under-vehicle locations.
I doubt you would still have your fingers if you touched it and it was over 450F. I would also ditch the plastic valve cover cover it is just going to trap heat.
Old 12-21-2010, 04:31 PM   #4
jouna
jouna's Avatar
[I]I would also ditch the plastic valve cover cover it is just going to trap heat.
ahhhh i liked my cover :-(
vvti bregao!
Garm's CF Wrap LA Yaris California 15 07-29-2010 07:01 PM
LEDs and heat SaerinRhoe Cosmetic Modifications (Exterior/Interior) 10 01-02-2010 09:34 AM
heat barrier auto pal DIY / Maintenance / Service 1 06-27-2009 05:29 PM
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
General Warning and Fuel Tank Heat Shield ttufrosty General Yaris / Vitz Discussion 8 05-31-2007 10:59 PM
