No doubt you will pull heat off of the head... But having the radiator and fan blowing in that direction is not helping either, and wrapping it could block much of that.
#2 | |
![]() ![]() ![]() ![]() Drives: Vitz RS Turbo Join Date: Nov 2008
- The main problem of intake high temperatures is the contact with the head. - 2nd problem is the engine bay temperature itself. - 3rd problem is the air temperature inside the intake (For N/A engines this is around the same as above). - 4th problem is because of the engine the design the radiator fan blowing directly to the intake. So I ask if I replace the intake from plastic to aluminium, I would probably gain better airflow but with rather higher temperatures? Please discuss! What is your experience Garm on the custom alu intake? |
| Garm's CF Wrap | LA Yaris | California | 15 | 07-29-2010 07:01 PM |
| LEDs and heat | SaerinRhoe | Cosmetic Modifications (Exterior/Interior) | 10 | 01-02-2010 09:34 AM |
| heat barrier | auto pal | DIY / Maintenance / Service | 1 | 06-27-2009 05:29 PM |
| OEM foglight switch and leather wrap steering wheel | 808yarisLB | Cosmetic Modifications (Exterior/Interior) | 8 | 03-11-2009 12:05 AM |
| General Warning and Fuel Tank Heat Shield | ttufrosty | General Yaris / Vitz Discussion | 8 | 05-31-2007 10:59 PM |
