Old 12-28-2010, 01:07 PM   #1
toad
toad's Avatar
Drives: street-legal go-kart
i would stick with the either the oem denso or ngk IRIDIUMS. i just changed mine out a month or so ago with about the same mileage.
there's plenty of debate as to whether or not the iridiums actually do anything better than other grades, but all i know is i won't be changing my plugs again for another 100k miles!
i didn't know autozone made their own iridiums, but for a few dollars more per plug i'd go with the name-brand ones for piece of mind(it may be the last plug change you do on this car).
toad is offline   Reply With Quote
Old 12-28-2010, 11:26 PM   #2
slow.yaris
Drives: 07 yaris sedan
1) I've had autozone parts last longer than name-brand OEM parts
2) Those longer lasting parts also came with warranties
3) Autozone sells NGK
4) Autozone FTMFW ;)
slow.yaris is offline   Reply With Quote
Old 12-29-2010, 03:32 PM   #3
severous01
agreed. i went through 20 sets of 'toyota' wipers....and kept doin the parts warranty thing...well they stopped the parts warranty. so i shopped around. michillin, annco, bosch, rainX, and all sorts of other brands of inserts and whole blades. always streaking on the first swipe and never lasted more than a month. bought a set from autozone, the 'duralals' wipers for 12 bux a set....works perfect and going on 6 months now.
also, as long as you're not getting the cheapo, bottom tier stuff like brake pads or rotors, you can expect better than stock performance out of them. i like mid-grade or better myself when it comes to pads, and top tier when it comes to rotors. as for plugs and wires....they're all basically the same. but i'll never use bosch, and i wouldnt put champion in my lawn mower. other than that...delco, ngk, auto-lite...whatever's better in your opinion.
a lot of times what happens is when a patent runs out everyon and their mother will mimic that patent and make just as high a quality part as the big guys. the parts use the same materials, the same processing, and in more cases than not...the same plant and distributors/packaging companies. do some research on your companies. if you're in the grocery store check the labels. market basket uses 'parade' brand and if you look on there it's packaged in the same plants as KRAFT, oscar myer, McKormick, Betty Crocker and all the other name brands...and that means the same product.
Old 12-29-2010, 04:20 PM   #4
jstantherprsn
Drives: 01 Toyota Echo
The first thing I did was swap out the spark plugs when I got the car. I had original oems and replaced them with the new iridium fusion (platnium) plugs. Need the iridium because without it, they get to hot. They run great, the idle is smoother, I haven't had any problems and I got 4k on them now. There was a sale a while back so you got 2 bucks off each plug. I'll check them later but I doubt there will be and problems.
jstantherprsn is offline   Reply With Quote
spark plugs phenoyz DIY / Maintenance / Service 48 01-18-2023 02:26 PM
Spark plugs for yaris RS 2zrfe engine candy_red Yaris TS Talk 3 11-16-2009 01:20 PM
article on spark plugs and the fit kngrsll Performance Modifications 4 08-01-2009 11:50 PM
did autolite spark plugs screw up coil or coils ?? la_scanner DIY / Maintenance / Service 20 04-09-2009 02:07 PM
Upgraded Spark Plugs For Boost whooppee777 Forced Induction Forum 9 02-14-2009 01:53 PM
