Old 01-02-2011, 10:17 PM   #1
xbgod
Drives: "Burning It Down GTX2860RS XB"
not like I keep a cam grinder on hand you fuck-tard. Doing work and machining work to different things.
xbgod is offline
Old 01-02-2011, 10:25 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
you bought an assembled head. this means that: A: your 'tunner' doesn't know how to assemble a head, so you paid this Gude guy to do it for you, or B: you are lying to us about the specs you gave to Gude for your cams, because you've relied on "internet intelligence" to choose the numbers for your lift/duration on your cams.. it sounds like your "tunner" didn't do his job, and you're bouncing back to the yarisworld innanetz to complain.
yarisworld, disregard this assclown... he's spending money, but has no idea why... sad that he spent this much on a 1nz when a little bit of actual innovation would have yielded him over 500whp on the same car (with a 1zz) and a bit of actual innovation.
Tamago is offline
Old 01-02-2011, 11:18 PM   #3
xbgod
The tuner is not responable for building the head. He Tunes you retard!!!!
And the specs were not correct on the cams way too much over lap.
And I now know Gude dosen't even grind the cams himself, he sends them out. And apparently dosen't inspect or check them before sending them out.
You got a answer for everthing don't you. Take your gay MR2 and go to the forum that supports you.
XBG
xbgod is offline
Old 01-07-2011, 02:08 PM   #4
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
XBG
Um dont mean to be a dick but this is a dohc engine with vvti thats all in the setting of the valve timing this isnt a cam for sohc or pushrod engine where the overlap is speced into the grind of the cam. What is the information on the camcard you were given?
xnamerxx is offline
Old 01-25-2011, 06:03 PM   #5
xnamerxx
0-60 in slow
xnamerxx's Avatar
XBG
Well Gude dosen't give a cam card it's a crap shoot with this retard.
XBG
How could you possibly know if it had to much overlap if you didn't get a cam card.
xnamerxx is offline
Old 01-25-2011, 06:37 PM   #6
xbgod
From the engine builder and the tunner comparing the cams and doing the math.
And before you proceed any furether with this, do your self a favor and don't take this down a road your not willing to go down. I know you get what I'm saying.
XBG
xbgod is offline
Old 01-25-2011, 09:07 PM   #7
xnamerxx
0-60 in slow
xnamerxx's Avatar
XBG
Really so your "tunner" (spelled tuner btw) compared the cams and did the "math". What math did he do just curious?
The stock engine overlap goes from -2 - 12 degrees of overlap so tell me how does comparing old cams to new ones tell if it has more overlap? The overlap can easily be changed from modifying the vvti settings.
So basically what your saying is someone told you it had to much overlap and you agreed.
Btw making threats on the internet is the behavior of a child.
xnamerxx is offline
Old 01-26-2011, 06:26 AM   #8
xbgod
No, it's ass-holes like you that need to know everything and need to continue to poke at something.
So untill you can get that Yaris of yours to beat my numbers, you don't need to worry about me.
I'm doing things no one else is even doing. I don't even run vvti. I use an external crank trigger like a regular drag car.
So why don't you take you and your 29 post and go chime in on someone who gives a shit. Your a little late to ring in on my thread.
It was obvious from your previous post you were looking to start something. Just because you cant get your jelly bean to pull off what I did, don't go looking for reasons to hate and make your own ajenda of my success.
Sorry you suck at life.
XBG
xbgod is offline
GI: Custom Cams lilredrocket Performance Modifications 62 11-13-2009 10:10 AM
