#163 |
Drives: "Burning It Down GTX2860RS XB" Join Date: Sep 2010
Thats the best I can do for ya Cali. I even talked to the Jake at Tial he said that gold spring would never work either for 28psi. Has to be the grey/ gold to make it happen.
On the other hand.......and this is for Parma.......... Shifter cable was burned right through. 200.00 for a new one. Wrapping the new one in DEI shield and having a aluminum shroud with a heat resistant material from DEI put on the other side of it to also block the heat. You were right on with your S.W.A.G XBG |
#164 |
i went through a set of cables after my turbo build too. it was a struggle. toyota put the cables dangerously close to the stock exhaust, and when you upgrade "go bigger" you immediately heat up your stock cables.
good luck Aras (asshole).
#165 |
![]() ![]() ![]() Drives: Scion xA Join Date: Oct 2009
looks like promising results so far. Hey remember i mentioned the wastegate spring a couple weeks ago.... hehe. I remember looking at your build pictures, one thing that is probably causing the creep is the fact your recirculating dump is kinda short and dumps at a perpindicular angle into the downpipe. The exhaust flow from the downpipe may be causing pressure in the dump therefore causing a reverse wastegating effect... boost creep. Worst case run an open dump. Having the wastegate opposite from turbo entry won't help either, but with a top mount log manifold i guess there is no place else for it. Your gonna run a lot of boost anyhow so creep wont really effect u at 30psi. With a proper wastegate spring, you should be able to hold 30psi all the way to redline with that turbo I would imagine.
Ptuning.com |
#166 |
Your so kind Tamago.....Thanks brother.
And I think your right about that.BlownXA XBG |
#167 |
ooh 30 psi... nom nom nom
#168 | |
So, desired boost pressure is a combination of exhaust pressure, spring pressure and vacuum pressure. The only one we have control over is vacuum. |
#169 | |
![]() ![]() ![]() ![]() Drives: Vitz RS Turbo Join Date: Nov 2008
![]() The yaris engine bay is too compact to go extreme without issues like these... |
#170 |
![]() ![]() ![]() ![]() Drives: 2008 Black Sedan Join Date: Oct 2008
Did your hood scoop help much in reducing underhood temps?
#171 |
my downpipe is 3", along with the rest of the exhaust. I haven't had any problems with trans cables. Must be a different downpipe shape than you guys have.
#172 |
Don't know on the hood scoop thing.
when I'm on the dyno my whole front end is off and my hood is open. Like You Parma my exhaust is 2.5' all the way through as well. Cable should be in today and new wastegate spring by thursday. Then back at it again. XBG |
#173 | |
#174 |
Well Cable has been reinstalled and DEI heat wrapped along with this fabricated shroud to block the heat. Waiting on the spring to show up for the wastegate.
But in the mean while I went ahead and had the gear oil changed in the tranny. Put back in Amsoil MTGQT 75-90 figured since I was in there may as well start fresh. Well thats where were at today guys XBG |
#175 |
how long do you think that transmission is gonna last?
#176 |
^ who knows, mine is holding up well, and Art raced the crap out of his xB at 280 whp.
#177 |
my 6bolt echo transmission lasted 5 months at 160+ whp :(
#178 |
^ bleh. I'll pray more.
#179 |
Yeah the trans. Is the weakest link in this car. And with not alot of after market parts available, it is was it is, a time bomb.
I'm using a Fidenza 4.3 clutch and flywheel in this trans and that's about it. Nothing else real special. Should this thing shit the bed I contacted Chris at Kaaz for a new build at their facility. Will use their Lsd and have the gears cryogenicly treated, use the same Fidenza parts let them do all the work and then reinstall. That's about all I'm gonna be able to do and then let it ride. XBG |
#180 |
Man u must be made of money
| Want to build costom turbo kit. Need advice from boosted guys! | pimp my yaris | Forced Induction Forum | 639 | 09-28-2013 11:26 AM |
| FS: 2005 Scion xA RS2.0 Turbo | uberegg | Cars for Sale by private party | 40 | 04-03-2010 11:45 AM |
| Scion xd turbo | PARIS | Yaris TS Talk | 22 | 02-26-2010 08:08 AM |
| Chevy Aveo RS: Turbo + good looks = build it! | Thirty-Nine | Off-topic / Other Cars / Everything else Discussions | 22 | 01-12-2010 12:36 PM |
| Check out the new Scion iQ concept. In the States in 2011/2012 | LA Yaris | California | 9 | 10-23-2009 08:11 PM |
