Crazy Oil Sniffer
Drives: MM 09 Yaris 5 Dr LB "Click" Join Date: May 2009
I am hopeful swidd was joking.(?) Dumping coolant into the environment is NOT a good idea. Ethylene Glycol is extremely toxic and a relatively small amount can kill a child or small animal who may be attracted by it's sweetness. Who knows where it will end up. Collect it and recycle it. It doesn't take much more effort to be responsible.
#2 | |
Bronze bombshell yaris
Drives: 09 Yaris HB 3door Join Date: Sep 2010
Dead cat.
Now I drive a CARMINE RED METALLIC 09 Yaris 3-door!! I'm Back!!! WooHoo!! Mods done so far: Tinted windows, Viper 211HV Remote Keyless Entry, Atoto Android headunit, backup camera, steering wheel controls Before it was totaled I drove a 2007 Black Sand Pearl 3 Door Lift-Back M/T with 49k miles. Stock Everything except for black tint, all red badges, red dash, and stealth garage door opener. Ultra-Gauge mounted on steering wheel. A1 Electric MES Central Locks and Avital 3100 Alarm system.
![]() Drives: Yaris 2007 3 doors Join Date: Jul 2009
Timing belt
I don't see anywhere the timing belt being mentionned
do we have a timing chain in them little engines , or is that something not mentionned anywhere for interval replacement ???? .. .. found an old subject on the web .. .. "Power is from the 1NZ-FE 1.5-liter four-cylinder engine familiar from the Scions and the Prius. Here is makes 106 horsepower at 6000 rpm, with 103 lb-ft of torque at 4200 rpm, and drives the front wheels through either a five-speed manual or four-speed automatic transmission. Like most current Toyota engines, it is an aluminum alloy unit with dual overhead cams, four valves per cylinder, VVT-i variable valve timing, coil-on-plug direct ignition, and electronic throttle control. There is a timing chain, not a belt, for lower maintenance. " .. I guess that answeres my question , timing chain , HOURRRAAAAA !!! Last edited by Kazimodo; 02-07-2011 at 02:03 AM. |
#4 | |
![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris S Sedan 5-Speed Join Date: Oct 2008
Saves about $800-$900 every 100K. |
| Performance mods that won't affect/will hardly affect gas mileage?? | Mr.Yaris | Performance Modifications | 15 | 07-30-2007 12:32 AM |
