Bronze bombshell yaris
Drives: 09 Yaris HB 3door Join Date: Sep 2010
Which is lighter, small rims/tall tires or big rims/thin tires?
Ya know.. same actual diameter of the 2 wheel/tire combos.
Just something that popped into my head... was just thinking about reading earlier on here that the rotational inertia of the wheels really effects our small cars so the lighter the tire/wheel combo the better. My guess is the large rim very thin tire? (probably makes for a really bumpy ride tho) Just wondering, not really in the market for wheels/tires... heh
Now I drive a CARMINE RED METALLIC 09 Yaris 3-door!! I'm Back!!! WooHoo!! Mods done so far: Tinted windows, Viper 211HV Remote Keyless Entry, Atoto Android headunit, backup camera, steering wheel controls Before it was totaled I drove a 2007 Black Sand Pearl 3 Door Lift-Back M/T with 49k miles. Stock Everything except for black tint, all red badges, red dash, and stealth garage door opener. Ultra-Gauge mounted on steering wheel. A1 Electric MES Central Locks and Avital 3100 Alarm system.
Drives: 07 yaris sedan Join Date: Dec 2010
nope.
small rims/tall tires - lightest 15 inch rims start at 9 lbs. I haven't seen 17s under 17 lbs. The tire difference with the two is maybe 2-3 lbs. |
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
more metal is more dense. plus, not to mention the fact that the larger diameter rims are wider.
cools, makes sense. I just thought the opposite seeing all these high performance cars with huge rims/very thin tires.
with those cars pushing 400+ hp, i dont think 10 extra pounds on each wheel is noticeable. but 100hp, yea.. lol
#6 | |
Surprisingly tire size does not change the weight nearly as much as wheels, the difference between a 15" and 17" tire may only be a 2lbs - this is using the same brand and same model of tire. As the diameter of the tire gets bigger, so does the hole in it, you will typically only see an increase in weight if the circumference or width of the tire is increased. We tested this back to back on the track... A 5lb per corner weight increase (this was using identical size and offset wheels, both with the same exact tire, the only difference being a 5lb increase in wheel weight) varied between one and two tenths of a second slower per lap on a 45sec autocross course. In the end smaller is lighter, but its not always the best performance package... For a street car, get what you like, and don't sweat a few pounds.
+1
http://www.youtube.com/user/ProjectYaris |
well, if all youre talkin about is weight smaller is better. but you'll usually get a better reaction and feel for a lower profile tire, to an extent. 40-50 series tires feel much better than a 50 or 70...but once you get blow 45 you tend to get really stiff and and they break before you can feel them going...
so, its all up to you and what you need and feel you want. i like economy in the yaris....so lighter is better. and with the yaris, i'm not so much into performance. i dont have ABS or tons of power....and the yaris can't break a 15 sec so performance or so traction isnt an issue isnt an issue. so to me, steelies and a 195 is the way to go. |
#9 | |
2012 CBR1000RR Hoo Yaaa
Drives: 08 3 door Hatch Join Date: Oct 2008
Not sure how it works with cars, but with bikes, less weight = less rotational mass = faster turn in..
Former Admin on a Moto site |
Performance and race cars also usually have large wheels so they can fit in bigger brakes.
I went from heavy-ish 18" wheels with skinny lil 215/35 tires to 15" lightweight wheels with 195/50 tires last year, and it was a world of difference. I was afraid it would make the car feel less precise in a wobbly way, but not really. But, it's far more comfortable now, and the overall diameter is actually smaller (195/55's would be more or less equivalent to stock wheel diameter), so it gives a bit of an acceleration boost (at the expense of fuel economy, but due to the lighter weight, this is unchanged!). They just feel grippier too, but that could also be due to the tire compound too. So yeah, for a car like this, small, lightweight wheels FTW :D
I have two sets of 17's. One wheel and tire combo weighs 40.x lbs. The other combo weighs 37.x lbs. Cruising on the street doing 40 mph (throttle at 20%) in the first set gives me 36-38 mpg (mpg gauge on SGII). Cruising on the same street at the same mph at the same throttle % on the second set of 17's, I'm getting 55-60 mpg. First set is 17x7.5" with 205/40/17 tires and the second set is 17x7" with 205/40/17 tires.
I know it's not comparing two different size rims, but just food for thought. |
![]() ![]() Drives: Yaris 08 Join Date: Mar 2009
I have see Konig lightspeed 17X7 for 15.5 lbs
Some rims are less, I got 18's they weigh about 13lbs each the rim alone with the tires IDK
Since the difference between the weight of the smaller vs larger rim-diameter tires is very similar, and most of their weight is at the tread, they don't make much difference in terms of inertia.
However, because rims have a good bit of their weight in the hoop, and the larger the rim the further away from the center that weight goes, the more inertia the larger rim has. My racing rims are 13x7.5 Lenso's and my street rims are 15x7 Motegi Traklite 2's :) |
#16 | |
![]() ![]() Drives: an egg Join Date: Aug 2010
SSR Type F |
#17 | |
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Feb 2007
![]() ![]() ![]() Drives: 2010 5 door hatch w/5 sp man. Join Date: Jan 2011
What is the weight of the 15 inch OEM steel wheels that come with the Yaris?
| Newly installed 15" tires feel 'weird' | kristan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 04-24-2010 06:58 PM |
| Whats the big deal with 5-lug applications on small cars? | marlondog | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 28 | 12-16-2008 07:22 AM |
| Want to go "Retro" with small thin tires and chrome hubcaps (aka 1950's look) | gaffo | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 7 | 04-24-2007 07:22 PM |
