#163 |
MetalShark
Drives: 2008 Yaris LB Join Date: Oct 2008
Tach dreamer update: I've finished the 33 LED analog display installed in the display trim similar to my earlier BS2 tach. Those of you from the LA basin may have seen the only operational prototype of the gen 1 tach. I've finished the firmware (with the help of Prallax.com forum members) on a breadboard for a digital readout. It's running in my Yaris today. I'm changing the 4x7 segment display from red to green. I had a setback learning to solder surface mount chips for the analog display.
I'll have to do a version 1.1 layout before it's kit ready. I love the headrest video camera mount I found here. When success is apparent watch for the video coming soon to a forum near you.
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header. Last edited by metalshark; 10-15-2010 at 12:15 PM. Reason: grammer |
#164 |
![]() ![]() Drives: 2zz MR-2 Spyder Join Date: Nov 2010
Wiring question
A question for this installation....
Could you also tap the tach and illumination wires that plug into the main speedo panel? There is a tach signal even for cars without a tach display. I know becuase I plugged a canadian panel into an american liftback and the tach worked fine. cheers |
#165 |
Drives: 2007 toyota yaris Join Date: Dec 2010
putting a stock cluster,w/tach in a 2007 HB.
i would like to put the instrument cluster w/ tach, in a us spec, 2007 hatch back.
will the cluster physically fit, and how much of the wiring to the cluster would have to be re done? has any body tried this before? thanks for any help in this area. bob smith, ohio |
#166 | |
#167 |
hey guys! i just installed my tachometer yesterday!
special thanks to mr. CTSCOTT for the wiring suggestions! will post pic soon. orayt! next stop, suspensions! :))
Live, Laugh, DRIVE! |
#168 |
![]() Drives: Yaris lift back, red Join Date: Aug 2009
Tach is important to me. Hearing aids, and excess road noise make it impossible to hear the little hum of the engine.
#169 |
![]() ![]() Drives: 2008 Yaris 3dr Hatchback Join Date: Oct 2010
RPM check
Just installed my tach and wanted to compare RPM's to make sure it is accurate.
2008 3dr, 5 sp manual. Turning 3000 at 70 mph. 2500 at about 60. |
#170 |
That sounds right
Mine reads about 2800 @ 65mph in 5th Yours is callibrated/configured properly for a 4 cylinder. Last edited by RedRide; 04-09-2011 at 10:25 PM. |
#171 |
147K-Blue / 24K-Yellow
Drives: 2010 Ylw 3dr. AT(Blue-Wife's) Join Date: Mar 2011
Brainr4
There isn't much diff between the Auto and 5 speed, (I imagine thats why the epa guesses we'll get nearly the same) I'm running about the same "R's" with my auto...a drop to 3rd puts me at 4300+/- @ 70.
All Weather Package, Power Package, Cruise, WeatherTech Floor Mats. Altimax Arctic Winter Tires. Repair List: 1 new blower motor, making funny noise. @ 91K (Water pump @ 120K) Mod List: 1. Black tape on most of the annoying blue high beam light behind the lens. (thank you CTScott) |
#172 |
Thanks!
I didn't think I would be turning so much at 70mph. If we had a 6 speed gas mileage would be close to the Prius. Ha, I guess that is why they would never put a 6sp in the Yaris! |
#173 |
Just installed my tach, 3 3/4" Glowshift Elite 10 Colour. Behind the steering wheel with full access to the glovebox behind it c:
![]() [Taken with Nikon D3000 w/ 10.5mm Fisheye] |
#174 |
Not quite a noob
Followed this DIY, works fine. You can actually use any of the "top" row of the OBDII connector for ground.
#175 |
![]() ![]() ![]() ![]() Drives: 2007 Yaris manual dark silver Join Date: May 2006
why would you though when there's a body ground right there
7 Color Tach Fujita Intake Momo pedals Shift knob and boot. Full TRD SSK. Blitz exhaust Megan Lowering Springs (Next is DC Header) |
#176 |
Right where?
#177 |
There's ground right by your left foot. read the diy. why would you want to ground to a obd2 rather than a factory ground point
#178 | |
I did that out habit more or less as most all Toyotas have factory ground pont there. However, the OBD2 is closser so why not use it? |
#179 |
The factory ground is better. Why tap into a wire thats a foot away from a ground point? The factory ground is exactly that a ground its not a obdii point it has a purpose use it.
#180 | |
A tach is a very low current draw item and the OBD2 ground is more than adequate. Don't loose site of the fact that if you are getting the tach signal frome the OBD2 to begin with, it will also be good for the ground. All modern tachs use LED/low current lighting. Otherwise, it would be like runninng a perfectly adequate 24ga wire for an item's positve and then, runing an 8ga wire for the ground for example. There would be simply no need for a 8ga ground. Last edited by RedRide; 08-12-2011 at 09:29 PM. |
| Liftback Spoiler Installation | Toddhata | Cosmetic Modifications (Exterior/Interior) | 25 | 08-09-2009 01:26 AM |
| US Yaris: Adding a tach? | Thirty-Nine | General Yaris / Vitz Discussion | 159 | 04-05-2007 08:23 AM |
