Yes that's correct. On th C160 there's also a bolt of the same size on the very top you can us to pour the oil into. Just leave the one on the front open to know when it's full.
![]() ![]() ![]() ![]() Drives: Vitz RS Turbo Join Date: Nov 2008
The top of the transmission is a definete no way since there is too much to unplug/unmount to access it
![]() Drives: AE101 Join Date: Jan 2011
Hi all,
I am C160 Gearbox owner too. The Oil replacement done by normal mechanic that 1st time seeing C160. The top holes are thru one. meaning oil can over flow to another when over filled. and the bottom are the drain plug. I have a question here too. All my buddies said C160 consume 2-2.5 litre of oil. But when I drain my oil, I can manage to drain out about 1.7-1.8 litre of oil only. second question will be, what is the correct rating of gear oil we should use, I tried toyota LSD 85w90, it cause not smoothness on gear shifting. I wonder am I using a wrong oil or not. I know most of ppl are using motul and torco 75w90, Is there any alternative oil that is less expensive in the market? |
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 07:18 PM |
| Gear oil change choices (Canadians) | Jem_hadar | DIY / Maintenance / Service | 17 | 08-29-2009 11:51 AM |
