![]() ![]() Drives: Yaris 2010 Liftback Join Date: Feb 2010
i use a water tunnel in my lab. i've been thinking about this. with a properly designed rear wing on the hatchback, it may be possible to increase fuel economy.
![]() the top picture is similar to a stock yaris, air swirls in vortex patterns, which means that not only does the yaris need to propel itself forward, but spend considerable energy into moving air. with the correct rear wing, there could be less separation in flow at end and less movement in the air, similar to the bottom picture. i found this picture online, the second picture is misleading because it represents an ideal case with virtually no separation in flow. the antennae will disturb how the eddies are shed, reducing wasteful swirling of air (reduce a little). similarly, if a wing is designed to reduce the size and number of eddies from forming by increasing turbulence at the rear of the car, the car will have less drag and overall better efficiency. |
#2 | |
![]() ![]() ![]() ![]() Drives: 3-door hatch Join Date: Oct 2010
#3 | |
The reason I was thinking about a wing is that it is larger and easier to test in the water tunnel at my lab. The job is the same, to trip turbulence that will be helpful in reducing drag. The equipment I use has lasers measuring the movement of small aluminum particles in water to visualize the flow on a computer. However, unless if the changes are drastic, this equipment probably wont accurately show the influence of tabs on a miniature yaris. BTW, does anyone know where i can find a model yaris? |
| FS: not a car... 2004 600rr low miles (SoCal) | AdeJong 03 | Cars for Sale by private party | 8 | 09-25-2009 12:13 PM |
| Clazzio Seat Covers at LOW LOW Prices!! | Sparks Toyota-TRD | Sponsors Classifieds Area | 11 | 08-06-2009 05:02 PM |
| im looking for rota or drag rims dealer in toronto!!! | marcus | Cosmetic Modifications (Exterior/Interior) | 15 | 05-27-2009 12:44 PM |
| CLAZZIO SEAT COVERS at LOW LOW Prices!! | Sparks Toyota-TRD | Sparks Toyota | 1 | 04-02-2009 11:47 AM |
| Auto Shop Local Bay Area Genuine Toyota Parts Low Low Price with Warrenty | YarisSedan | California | 1 | 10-31-2008 09:32 PM |
