Old 01-09-2011, 10:33 PM   #1
H3LlIoN
Drives: '09 Yarrrr hatch
It can be done in one, but you will at minimum need a transmission jack, a floor jack, and some jackstands, as well as a second person, or an oil pit and tall tranny jack. It's really not that hard...if you have any questions about the procedure, you can PM me here or @ MI and I will be more than happy to help in any way I can. I don't always follow threads on here, so PM is probably best. I'll post the PMs to the threads though so that anyone else will have the info.
Toyota
Moving Forward
...even when you don't want it to.
Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
H3LlIoN is offline   Reply With Quote
Old 01-10-2011, 05:14 AM   #2
victorddr
Drives: 07 Yaris CE
Wondering how high I should lift the vehicle up to get enough clearance to pull the tranny?
Can I use the floor jack to lower the tranny or I will need an tranny jack adapter to do the job?
victorddr is offline   Reply With Quote
HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. trini_per4mance DIY / Maintenance / Service 42 03-27-2017 03:59 AM
Clutch shudder when setting off in 1st gear BuildCode DIY / Maintenance / Service 87 06-17-2015 07:14 AM
Help Me Find The Right Clutch RacerFreakXXX Performance Modifications 18 10-20-2010 05:20 PM
Thinking about flywheel & clutch... MGargano Performance Modifications 10 09-13-2009 12:11 AM
Having clutch issues ? hystria DIY / Maintenance / Service 10 08-22-2007 11:34 AM
