Old 01-10-2011, 06:29 PM   #1
slow.yaris
Drives: 07 yaris sedan
Sorry, but I like not fearing every pothole and speedbump that I come across, nor do I relish the thought of rubbing every time I try to turn a corner.
Plus, not all Yaris owners are kids; some of us don't want to look like all the dropped Civics and Neons bouncing down the roads, fart cans making more noise than power, blasting distorted hip-hop, hats on sideways and pimp daddy sunglasses looking like a gay version of Eva Longoria!
But if you want to look like someone squashed your car, than that's your choice!
Wow.
First of all, lowering a car is not as dangerous for potholes as having huge ass wheels with rubber band tires. Also, nobody that I know of lowered on 15s rubs, its when they go to 17s.
Second, the stock yaris bounces a lot more than my car, and blingy big ass chrome wheels are much more in line with the "sideways hat hip hop" scene than a lowered yaris. Lowering increases looks AND performance. Your rims rob performance, both acceleration and handling, and are solely for looks, which are obviously objective.
I prefer not to have roller skate wheel gap, and to be able to control my car in more than 10 mph winds.
PS - your real 4x4 is what flips on the trail and gets pulled out by a stock tundra, if it makes it to the trail at all without flipping or the chassis separating from the frame in an accident... oh, and there's douchebags that like flipping rocks into peoples windshields and sacrificing their own safety as well as anyone else they hit in an accident all over the world, not just TX.
@other guy - 4 exhaust pipes... 'nuff said.
slow.yaris is offline   Reply With Quote
Old 01-10-2011, 10:32 PM   #2
MadMax
MadMax's Avatar
Originally Posted by slow.yaris View Post
Wow.
Dude, you drive a sedan....'nuff said!
Old 01-10-2011, 10:43 PM   #3
slow.yaris
Its cool, ignoring my points is as good for me as you saying "I'm wrong and can't refute anything you said, my rims are goofy and make my car slow"
Old 01-11-2011, 06:38 PM   #4
MadMax
MadMax's Avatar
Well, since I have to spell it out for you...you didn't make any points, so there was nothing to refute!
But you can continue to believe you "schooled" someone who has probably been driving longer than you've been alive! Now go away and let the adults talk!
Brendan, I really like your car; and would much rather drive it than some lame sedan!
And 33OH, I don't think that's correct, as if you compare the picture of the car with 15" wheels to mine you will see that the gap is significantly smaller on my car. It has more to do with offset than it does wheel size.
Old 01-11-2011, 06:49 PM   #5
slow.yaris
The ignorance continues. Offset and wheel gap are on different planes. Wheel/tire size and wheel gap are on the same plane.
Old 01-11-2011, 08:18 PM   #6
xbgod
Drives: "Burning It Down GTX2860RS XB"
You guys are brutal to each other. If the dude likes the gap...........Who cares? it's his ride. There are so many combinations to achive a certian look out there and that's what makes us all different. You can virtually run what ever tire/whell combo you want with the right suspension set-up.
I don't know mabey one of you should do a killer JDM set-up with some killer camber-offset and tuck those wheels a little as well.
Oh, but you'll need more than some cheap ass springs. Perhaps some Double adjustable coil-overs and camber plates. Now were talking about getting a real agresive look. Mabey get some JIC Majic , Megan, K-Sport or some other bad ass way to truley adjust your ride height. And then hey, run what ever tire you want...........because it won't matter, you can adjust it to your likeing.
But hey this is just my opinon.
Enjoy arguing
XBG
xbgod is offline   Reply With Quote
Old 01-11-2011, 10:12 PM   #7
33OH
Drives: '08 Yaris
The gap is more significant because the tire size is smaller than yours. 195/50/15.
Old 01-11-2011, 10:16 PM   #8
33OH
Drives: '08 Yaris
And it has nothing to do with offset, which is how far the hub mounting surface is from the face of the wheel. Aka backspacing.
Old 01-11-2011, 10:45 PM   #9
xbgod
Now this looks BAD-ASS
Old 01-12-2011, 08:03 AM   #10
MadMax
MadMax's Avatar
Really? I think it looks ridiculous, but I live in the land of Mexican lowriders and there's nothing more amusing as watching them bottom out when going over a speed bump! That thing would self-destruct if driven like that on roads around here!
And Soni, I had thought about lowering mine for a while now, but I just don't see the need. I like the way my car looks as it is, it handles great and if anything, I am concerned about rubbing. Dropping it a inch or so really won't make that much difference, and I suspect the handling gains are nominal (and imaginary in some cases) if at all.
Cheers! M2
Old 01-11-2011, 12:31 PM   #11
33OH
Drives: '08 Yaris
This really has nothing to do with the wheel height. Running proper tire size, the diameter will be the same. It mainly occurs because when wheel diameter goes up, the width tends to go up as well. For example, you will never see a 17x5.5 but 15x5.5 is more common. Also, offsets play into this as well.
But you can lower a car on large wheels without rubbing if you run proper tire size and get a higher offset wheel. A 17x7 +45 would not rub with a drop from any lowering spring.
BTW - I've never rubbed on either set of 17's I've owned (17x7 +43 and 17x7 +40) but I rubbed like crazy on my 15x7 +19 MOMO's.
Tags
17" wheels, shopping, stock suspension
14 inch wheels .Kevin. Wheels, Tires and Suspension Forum sponsored by The Tire Rack 26 07-01-2011 09:28 PM
WTB - stock wheels fmicle California 2 10-07-2010 10:09 PM
FS: Stock steel wheels and hubcaps letstry1234 Items for Sale by private party 0 06-22-2009 12:31 PM
LOOKING FOR STOCK 15" STEEL WHEELS SOBERDOPEFIEND31891@YAHOO Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 04-23-2009 01:31 PM
Selling my Stock Suspension 3 dr hatch alch3miss Great Lakes 5 03-27-2009 10:23 PM
