#253 |
0-60 in slow
Im pretty sure the power is giving up so early because the turbo is to small for the amount of power hes making. You can see it in the torque curve how it starts to die at 5k rpm's. Dont know the specs on his cam or the rpm range of the intake he's running but Id have to hazard a guess and say both are rated for something like 3-7.3k rpms but the turbo doesn't have the cfm to keep up.
If you look at the compressor map for the disco potato it gives up on at about 35 lb per minute with 2.2 bar. Rule of thumb is 10 hp per every lb per minute so easy math says 350 hp give or take 20 hp. |
#254 | |
Bathroom + Laptop = <3
Does your standalone tell you the duty cycle the injectors are running at. Looking at that graph seems like you have something more to work with, like a handful of the people here say. |
#255 |
0-60 in slow
Its a walboro 255 so it should be good for the power the injectors are 60lb which are again probably good for the power hes making. We don't have the fuel rail pressure nor do we have duty cycle so those are 2 unknowns.
But seeing as the Yaris was never engineered to have 350+ hp id be willing to be the fuel lines from the tank to the engine are to small. Garm what are you running for fuel lines? 8an? Im not trying to bash xbgod on his build to each their own poison but running that dangerously lean and nitrous will result in a nitrous backfire which will blow your intake off the car. If the fuel issues get fixed and you run nitrous please do not go over a 50 shot with this small of a motor or you'l get to meet mr puddles and blow your intake up and probably wreck your turbo. Trust me with this I have nitrous on another car and I've run a 150 shot there is nothing scarier than watching your fuel pressure drop from 39 psi to 24 psi for a microsecond and jump back up. |
#256 | |
![]() ![]() ![]() Drives: Scion xA Join Date: Oct 2009
Ptuning.com |
#257 | |
#258 |
0-60 in slow
No one here is hating on him they are all pointing out a giant problem with his afr.
Ever wonder why evos, sti, cobras, vettes, vw's, or any other car that has a forced induction engine runs at afrs around 12:1 or less its not because there trying to sap power from the motor its because running any leaner results in detonation/pre-ignition and combustion temperatures that are to high. ![]() Hey what do you know on a STI the afr is less than 15:1 what a shocker and hey its running meth what do you know. |
#259 | |
#260 | |
![]() ![]() ![]() ![]() Drives: Vitz RS Turbo Join Date: Nov 2008
#261 |
![]() ![]() ![]() ![]() Drives: Yaris LB Turbo Join Date: Aug 2006
#262 |
^ I have a ported head with stock cams, so I don't think that's it.
#263 |
Garm, like said already ...you are looking at the torque curve. The power hardly drops off. As far as afr's, im not gonna speculate. We have run 13.0 on our race car for good numbers on the dyno, it liked running lean. But after the insane power pulls were done we immediately corrected the afr's for racing trim. It may very well be the same in his case. Only his tuner can answer that question about the afr's on that particular pull, but what everyone failed to notice, is the pull ended early around 6000rpm . So my guess is the tuner let off knowing. The car may have made the best power on that pull so that is why it was posted. Only other reason for pull showing an end at 6000rpm would be because rpm's were based off roadspeed and the graph got trunkcated do to tire expansion.
Ptuning.com Last edited by Blown_xa; 01-16-2011 at 03:16 PM. |
#264 | |
1. You didn't answer if you were including me in the word "haters" that you used.
2. Yes, I was looking at the torque curve. Regardless of which curve you'd like to discuss, the motor peaks very early; I asked why. I disagree with you that "The power hardly drops off." It's done at 5200. It drops off enough that the tuner stopped the pull early, as you noticed. 3. You can "not speculate" on the AFR's all you want -- but the dyno got posted and we get to discuss it, right? That looks too lean to me. (I could always be wrong, but I don't think I am on that detail). Quote:
#265 |
#266 |
OK, I can't argue because I don't know enough, I'll admit that. Maybe the porting job alone gave him a power curve where horsepower is done by 5200. Were there some pics posted of the head? I can't remember.
#267 |
Pics alone cannot give you any information. A flow chart is needed.
#268 |
0-60 in slow
Since you seem to understand this subject so much explain why a stock yaris is able to keep making power past 5200 rpm's and this dudes motor is out of steam at 5200 rpm's.
All I want is a explanation as to why that would be the case. |
#269 |
#270 |
0-60 in slow
Yes, I want a explanation as to why a very modded car is plateauing in power at 5200 rpms where as a stock yaris would not be doing that if it really was a problem with heads and cams.
| Want to build costom turbo kit. Need advice from boosted guys! | pimp my yaris | Forced Induction Forum | 639 | 09-28-2013 11:26 AM |
| FS: 2005 Scion xA RS2.0 Turbo | uberegg | Cars for Sale by private party | 40 | 04-03-2010 11:45 AM |
| Scion xd turbo | PARIS | Yaris TS Talk | 22 | 02-26-2010 08:08 AM |
| Chevy Aveo RS: Turbo + good looks = build it! | Thirty-Nine | Off-topic / Other Cars / Everything else Discussions | 22 | 01-12-2010 12:36 PM |
| Check out the new Scion iQ concept. In the States in 2011/2012 | LA Yaris | California | 9 | 10-23-2009 08:11 PM |
