Old 02-12-2007, 10:37 AM   #1
mrrock
Drives: yaris 2dr hatch
I've got the Tanabe NF's and 205/50/16's on BBS and I've had to modify the front inner plastic liner so they don't rub: bent the front and back metal tabs and then used a heat gun to modify the plastic liner at the tabs
mrrock is offline   Reply With Quote
Old 02-12-2007, 12:50 PM   #2
Black Yaris
der Zeck
Black Yaris's Avatar
Ya'll are rubbin with 205's? What offset are you running.. I have 225/50R15's with absoluly no rubbing.... and I have plenty of room to lower... Teyrume with the supercharged Hatch is running the same size as me and he is lowered with no problems.... Ya'll must be running an odd offset
Old 02-12-2007, 01:28 PM   #3
dansides
dansides's Avatar
Drives: 07 3 dr
what offset do u have black yaris i would like to go to 225 50 15 but do not want them 2 proturde out past fenders also how many inches of tread meets the pavement .tks dansides
dansides is offline   Reply With Quote
Old 02-12-2007, 08:02 PM   #4
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
I had the same issue running 215/45ZR17. I actually had to change my fronts to 205/45/ZR17s so I wouldn't rub. The rears were and are fine. So right now I'm running two different tire sizes until I wear them out. I believe I have a +43 offset. Before I found this board, guys at Toyota told me 43 is what I should run. Tire guys didn't see a problem with that but the front inner fender has a weird shape and when I lowered it with the 215s, I rubbed a bunch and did some hacking to the plastic to remedy. It helped but I still had to change to 205's. Even with the 205s, I get some minor rubbing on u-turns.
Galavoxx is offline   Reply With Quote
Old 02-12-2007, 11:29 PM   #5
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
My tires rarely rub with 205 50 16s. My wheels are 16X7 +40 offset. Only on hard turns at speed, or large dips at speed will the tires rub the inner fenders in the front. The TRD strus should keep it from rubbing on all but the largest bumps at speed.
Old 03-14-2007, 01:20 PM   #6
dresden_k
Honda Convert
Drives: NCP91L
Do you guys think that 205/45/16 would rub, with most moderate lowering springs?
dresden_k is offline   Reply With Quote
Old 03-14-2007, 02:41 PM   #7
nurburgring
ringmeister
nurburgring's Avatar
Drives: YARIS 1.5
From what I gather, so long as you have the correct offset... for a 6.5" wheel its +40 for a 7" wheel +45, it shldnt rub at all.
Right ?
nurburgring is offline   Reply With Quote
Old 03-14-2007, 03:34 PM   #8
rwseattle
Rwseattle
rwseattle's Avatar
Drives: 2007 Toyota Yaris (BASE)
No rub
Hey, dresden_k
I drive on 205/45/16 with Tanabe NF210. No rub. Zero problems. I will post new pictures this week so you can check out the lowering situation. I need to clean the outside before posting new pix. Its drives great. I do still need a alignment but that will happen this Saturday. I personally believe that you should always do the alignment after removing the springs.
Rwseattle.
rwseattle is offline   Reply With Quote
Old 03-14-2007, 06:09 PM   #9
largeorangefont
Break'em off some.
Right ?
I get very minimal rubbing on full suspension compression.
Old 09-20-2007, 10:41 PM   #10
johnnypaseo
Drives: Toyota paseo
hey large ur yaris looks good thinking about getting the spring techs myslef i love the drop. I was just wondering if you had 195's instead of 205's will it still rub in dips and all
New 07 Yaris S need advice on 18's and springs OgDogg Wheels, Tires and Suspension Forum sponsored by The Tire Rack 48 04-27-2009 09:50 PM
Got new wheels, tires, and springs installed. largeorangefont Photo-Video-Media Gallery 8 01-22-2007 04:29 PM
Just put my new wheels on Ryosuke Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 07-18-2006 01:04 AM
Lets talk wheels birdy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 80 04-29-2006 01:13 AM
