#1 | |
However, I definitely think the ECU might see continuous low voltage at the AFR sensor and throw a code. More importantly though, it probably would throw the engine into open loop. No one has really tested this method of tuning on the Yaris yet, so I'm just speculating. Could this be where the Yaris and Echo ECUs differ? |
#3 | |
Awesome!
Drives: 12 Yaris/07 yaris Join Date: Dec 2010
at 17 there is a severe loss of power. when we had the bogging issue thats where it was, then the ecu would dump fuel and suddenly it had a ton of power. |
#4 | |
i have a couple of friends with s/c'd 2zz's, here is what was said via msn...
Awesome!
the tps sounds like it works.
i found a function in the fic to switch the o2 map to be switchable with boost pressure. now just need to test drive to see how well it works! it worked sitting in the parking lot, i was able to drop it down to 12.2 at idle. so it is tunable, now just trial and error to see how well it works. |
For one, the Yaris uses one AFR sensor and one O2 sensor. The Echo uses two O2 sensor, so it's not as smart when it comes to correcting fueling. That's why the Yaris has a better emissions rating than the Echo does.
And about the AFR running as high as 17:1. That's what I was taught at Toyota Canada during a training session a few years ago. It won't be 17:1 under any significant load, it's only under certain conditions like: crusing at 80km/h down a slight grade but you're still on the throttle. There's really no load on the engine, but it's not on DFC either. |
#8 | ||
All I was getting at is that it's possible to see a really high AFR while driving. As long as it's not under boost
Yeah sorry let me clarify... It's inaccurate to say that I'm running at 15-15.5 all the time outside of boost. Whenever I'm cruising I allow it to go that lean because it does seem safe to me since the engine is under a lower load than say, when under acceleration. I only say it seems safe because
1) under very low load the mixture goes as lean as 17-18 (DFCO). So shouldn't it be safe to run a little leaner than stoich at low loads? 2) like I said earlier, if you watch closed loop, it will go as lean as 15.4 WHILE CRUISING. Usually the AFR will hold more around 14.7 while accelerating. I attempted to emulate this behavior: 3) as I do approach a higher load on the engine, I keep the AFR under 15. And really, that's only under low load because I have a linear approach set up that begins when the manifold absolute pressure begins approaching atmosphere (and reaches 11.5 AFR by 5 psi boost). I definitely am no expert on this, so my tune is largely from what I've read and assumptions like the one's above. My goal was to achieve a safe tune that maximizes full economy. If you guys think I have the wrong idea, please let me know. |
#11 | ||
^ Hey I was going by what you actually said which was:
Sorry about that
![]() Think about it though. With such a small turbocharger, pretty much anytime you give the engine a decent bit of throttle you're almost immediately entering boost. So really most of the time is either spent cruising or in boost anyways. The lesson to be learned here is word choice means everything.
hehe, onward then!
Did you getting all sorted out yet?
Awesome!
well, the 02 map seems to work intermittently, at -27*C the car doesn't pull to hard, but... when its +5 i was able to keep up to a 350z, man was he shocked!
i need to do some more playing around and find a way to do some better tuning, will still need to do the exhaust, weapon r intake manifold, larger fmic and we have a greddy mbc to bump us up to 7psi. |
![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Sep 2010
lol what was wrong with the 350Z?
05' Echo Hatch - Greddy Supercharger - rear disc |
Awesome!
dunno, he had sweet sounding exhaust, car was painted flat black. i know there not that quick but i was expecting him to pull alot harder then what he did.
im gonna email greddy to see if they have a larger turbo that will bolt right into their kit. |
#18 | |
| Aem fic | 1.5ty | Forced Induction Forum | 17 | 08-16-2015 08:22 PM |
| aem fic $280 | 1.5ty | Items for Sale by private party | 1 | 10-22-2010 12:06 PM |
| Aem fic | 1.5ty | Items for Sale by private party | 24 | 10-05-2010 04:59 PM |
| AEM FIC works in Yaris......Sort of | cdydjded | Performance Modifications | 32 | 12-06-2009 02:58 AM |
| AEM FIC works perfectly | cdydjded | Performance Modifications | 58 | 08-03-2009 07:20 AM |
