Old 01-25-2011, 04:35 PM   #1
yarisbird
yarisbird's Avatar
Drives: 2007 Yaris HB Bayou Blue
I just completed the installation of cruise control in my 07 hatchback using the oem stalk that I purchased from e-bay and the cruise indicator module/light and wires/pins from CTScott. The cruise control works great.
Only problem is with the indicator light. It turns on for one second when the ignition switch is turned on, but when the cruise control is turn on there is no light. I installed it according to the instructions using splice tap connectors. All of the connections are tight.
CTScott, is there any diagnostic check that you recommend to determine why the light doesn't turn on when the cruise switch is pressed? I have a digital multimeter if that helps. Thanks for all your help.
yarisbird is offline   Reply With Quote
Old 01-25-2011, 04:40 PM   #2
Just to verify:
The blue wire is connected to the wire that goes to the ECM pin and one of the wires going to the stalk?
The white wire is connected to ignition switched power?
The black wire is connected to ground?
Old 01-25-2011, 04:51 PM   #3
yarisbird
yarisbird's Avatar
Yes.
The blue wire is spliced into the wire that runs from the ecm to the connector under the steering wheel. (pin #1)
The black wire is spliced to the wire that runs from this connector (pin#2) to ground.
The white wire is spliced to the pink wire on the connector under the ignition switch.
Old 01-25-2011, 08:37 PM   #4
Yes.
OK. There is something wrong with the module. PM me you shipping address again, and I'll ship you a replacement.
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 10:12 PM
