05-18-2010, 10:41 AM | #1 |
Drives: 2001 Toyota Vitz Rs Join Date: May 2009
How much to boost a 2nzfe engine..
Can anyone tell me the maximum boost that a 2nzfe can hold without making any damages to the engine please? Thanks
05-18-2010, 11:07 AM | #2 |
has the same compression ratio (10.5:1) as the 1nzfe
i wouldn't go more than 8psi on stock internals
Last edited by thebarber; 05-18-2010 at 02:30 PM. Reason: i can't spell, apparently |
05-18-2010, 02:17 PM | #3 |
Drives: Yaris LB Turbo Join Date: Aug 2006
Id agree on the above statement
05-18-2010, 02:46 PM | #4 |
Drives: 07 Yaris Turbo Join Date: May 2007
And it depends on how you drive. If you do a season of racing @ 8psi on a stock motor, you might definitely see some engine damage. You will have some measure of reduced engine life though, e.g., it's not going to run for 100,000 miles like that, just to be clear. (but the miles you get will be REALLY fun) |
05-18-2010, 07:23 PM | #5 |
Modded Moderator
Moved this to the forced induction section.
05-24-2010, 08:11 PM | #6 |
It can probably hold 1 or 2 psi more than the 1NZ because it has a slightly shorter stroke... 11.2mm shorter.
05-24-2010, 09:58 PM | #7 |
Some one send me a kit and we will find out
01-28-2011, 01:16 PM | #8 |
Drives: Yaris Sedan '08 Join Date: Sep 2009
Hi, but what is the better? Turbo or Supercharger for a 1.3l 2NZ-FE Yaris?
Greets. |
01-28-2011, 02:34 PM | #9 |
without getting into the pros/cons of anything other than the end result:
turbo > supercharger
01-28-2011, 02:36 PM | #10 |
And what is aprox the max HP I can get with a turbo on a 1.3 with std internals?
01-29-2011, 12:35 AM | #11 |
The Unicorn
Drives: 2006 Yaris 5D HB Join Date: Apr 2010
01-29-2011, 03:25 AM | #12 |
Drives: Toyota Vitz Join Date: Sep 2010
what about 1s zfe? how much boost it can hold on stock internals ?
01-29-2011, 11:44 AM | #13 |
^ I don't think anyone knows this for sure. Do it, then tell the rest of us.
01-29-2011, 11:46 AM | #14 |
Drives: 2008 Black Sedan Join Date: Oct 2008
What's the compression ratio on that engine? From that u can give u a gusse
01-29-2011, 12:32 PM | #15 |
01-29-2011, 12:54 PM | #16 |
I made 180 whp on 8-9 psi on my stock 1.5L 1NZ-FE.
with a little less displacement, you'd get a somewhat lower number, everything else being equal?
Thread Tools | |
Display Modes | |
Similar Threads | ||||
The Nitrous Thread | ChinoCharles | Performance Modifications | 116 | 02-16-2016 03:07 PM |
DIY: Intake Installation | redyaris | DIY / Maintenance / Service | 53 | 08-23-2014 05:34 AM |
A Mystery Oi'll Say! | Yar Is Word | Fuel Economy Forum | 16 | 05-11-2013 04:22 AM |
Remote Engine Start PT398-33070 | Reeves360 | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 08-26-2009 07:11 PM |
The last gas question | Tonavi | DIY / Maintenance / Service | 56 | 04-27-2009 08:40 PM |
