Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 02-01-2011, 12:56 PM   #1
waseemsha
Drives: Yaris 2009
Red face CAR ENGING NOT START
PLS MY CAR YARIS 2009 FLOOD IN WATER AFTER JEDDAH FLOOD
I CLEANED AND DRY ALL ELCTROICE PARTS .
AFTER THAT WHEN I PUT THE KEY TO START THE ENGINE TRYING TO START BUT FAILED ..
IF I DISCONNECT THE BATTARY AND PUT THE KEY IN START POSITION AND CONNECT THE BATTARY AT SAME TIME THE ENGINE STARTING BUT IF THE KEY BACK TO NORMAL POSITION THE ENGINE WELL STOP ..
PLS HELP ME
waseemsha is offline   Reply With Quote
Old 02-01-2011, 02:07 PM   #2
So, if the battery is already connected and you turn the key from ON to START, is does not even attempt to crank, but if you disconnect the battery, place the key is the START position and connect the battery it cranks, but only remains running as long as you keep the key in START?
How high did the water reach?
Old 02-02-2011, 01:16 AM   #3
syntax
syntax's Avatar
Drives: Yaris Sedan 2010 "shadow"
it seems that way.. very strange .., the floods in jeddah reached about 1 to 2 feet in some areas.
syntax is offline   Reply With Quote
Old 02-02-2011, 09:22 AM   #4
The first things I would check are the AM2 fuse and the "ST" relay in the under hood fuse panel. Next would be the IG2 relay, which is part of the chunk of plastic that the AM2 fuse is mounted in.
After that it's the ECM that controls the starting process, so the next thing I would do is to open the ECM case and dry it out or pick up a cheap junkyard ECM to swap in (I've bought Yaris ECMs off ebay for as little as $25).
Old 02-02-2011, 02:48 AM   #5
rosco
rosco's Avatar
Drives: YaRis ka!--Y?2011
Smile
PLS HELP ME
your car is not yet old and i believe that the warranty from abullatif jamil will be consider..as long as they include the warranty for ACT OF GOD(aog).i suggest to bring with them and check by the expert mechanic ..because your case is un usual.
(lawsamat aksan gib min abdulatiff jamil...akid had fi daman lisa jadida sinaten..(takriban)..mushkila hada matar..swaya fi bahar..inshallah..kunlu cun quais......salamalaikom)
rosco is offline   Reply With Quote
Old 02-02-2011, 07:08 AM   #6
batman_john72
batman_john72's Avatar
Drives: yaris y 2010 blue
As far as i know Act of God is not covered in our insurance & warranty...
batman_john72 is offline   Reply With Quote
Old 02-02-2011, 07:18 AM   #7
zsazsa zaturnnah
zsazsa zaturnnah's Avatar
Drives: 2010 Yaris YX
Exactly my sentiments!
zsazsa zaturnnah is offline   Reply With Quote
Old 02-02-2011, 07:53 AM   #8
rosco
rosco's Avatar
mukhang dito hindi...yun ang dapat maitanong natin sa ALJ.....
Old 02-02-2011, 08:16 AM   #9
zsazsa zaturnnah
Sorry to disappoint you but DAMAGE DUE TO FLOOD is not covered under the limited warranty as per the attached (Page 9). However, it is suggested to contact the dealer for further churvah!
Old 02-02-2011, 03:41 AM   #10
syntax
syntax's Avatar
@ waseemsha
سيارتك ليست بعد من العمر وأعتقد أن الضمان من عبد اللطيف جميل وسيتم النظر.. طالما أنها تشمل الضمان لعمل من أعمال GOD.i تشير إلى تحقيق معهم ، والاختيار من قبل خبير ميكانيكي.. لأن قضيتك الامم المتحدة المعتادة.
Old 02-02-2011, 03:56 AM   #11
rosco
rosco's Avatar
@ waseemsha
aba galing magsulat ng arabic ah....
Old 02-02-2011, 05:59 AM   #12
zsazsa zaturnnah
salamat sa google translate!
Old 02-02-2011, 06:08 AM   #13
rosco
rosco's Avatar
ms.zsa zsa..kilala mo si jojo ben ng mawarid?dati ka ba sa riyadh?
Old 02-02-2011, 06:25 AM   #14
zsazsa zaturnnah
Do you mean ARNOLD BEN?
Old 02-02-2011, 06:27 AM   #15
rosco
rosco's Avatar
oo si arnold ben...kasi tawag namin sa kanya jojo ben...may mazdang pula?asawa nya nasa military hospital...active siya sa basketball..minsan dumadayo sa khobar yung mawarid team for tournament.
Old 02-02-2011, 06:31 AM   #16
zsazsa zaturnnah
Kaklase ko ng high-school! 2nd year to be exact! Found him sa FB and nageyeball kami when I renewed my passport diyan sa Riyadh! Haus ata nila malapit duon sa Seteen Palace Hotel sa may Malaz! Marami ako kaklas nung highschool diyan sa Riyadh!
Old 02-02-2011, 06:03 AM   #17
syntax
syntax's Avatar
wahahahhahaha ! ! ! huling huli ni mama zsazsa
KCALB SIRAY - Photo Scavenger Hunt KCALB SIRAY Photo-Video-Media Gallery 5 03-02-2009 10:44 AM
LEGATO`` - Photo-Scavenger Hunt LEGATO`` Photo-Video-Media Gallery 1 03-02-2009 10:38 AM
New car shopping - long post littlecarlove General Yaris / Vitz Discussion 19 11-01-2006 10:58 PM
