Old 02-07-2011, 01:47 AM   #1
Kazimodo
Kazimodo's Avatar
Drives: Yaris 2007 3 doors
Timing belt
I don't see anywhere the timing belt being mentionned
do we have a timing chain in them little engines , or is that something
not mentionned anywhere for interval replacement ????
.. found an old subject on the web ..
"Power is from the 1NZ-FE 1.5-liter four-cylinder engine familiar from the Scions and the Prius. Here is makes 106 horsepower at 6000 rpm, with 103 lb-ft of torque at 4200 rpm, and drives the front wheels through either a five-speed manual or four-speed automatic transmission. Like most current Toyota engines, it is an aluminum alloy unit with dual overhead cams, four valves per cylinder, VVT-i variable valve timing, coil-on-plug direct ignition, and electronic throttle control. There is a timing chain, not a belt, for lower maintenance. "
I guess that answeres my question , timing chain , HOURRRAAAAA !!!
Kazimodo is offline   Reply With Quote
Old 02-07-2011, 07:35 AM   #2
Kal-El
Kal-El's Avatar
Yup, timing chain likely good for the life of the car.
Saves about $800-$900 every 100K.
Performance mods that won't affect/will hardly affect gas mileage?? Mr.Yaris Performance Modifications 15 07-30-2007 12:32 AM
