Old 02-08-2011, 04:02 PM   #1
splify
Drives: toyota yaris silver 2002 1.0
Im a total newbie at this where are the fuses ive only driven old micra before this
splify is offline   Reply With Quote
Old 02-08-2011, 04:18 PM   #2
The under-dash fuse panel is behind the access panel to the left of the steering wheel (on a left hand drive car) or to the right of it (on a right hand drive car).
This is a diagram of what you will see:
Old 02-08-2011, 06:08 PM   #3
splify
thanks il have a look and see if a fuse is gone hopefully its just that strange one all the other lights on dash work like doors temp and handbrake but not the speedo just shows to tiny red lines if its not the fuse does it look like i need a replacement speedo is it easy to replace a dash is it just plug in
Old 02-08-2011, 10:00 PM   #4
The other lights are powered off the circuits they are associated with, so with the GAUGE fuse out, they would still work.
If it does turn out to be that the speedo is bad, it is not difficult to remove and swap the instrument cluster. Th only issue is that your odometer will read whatever the replacement one reads.
DIY LED Strip under the door panel charleschia1986 DIY / Maintenance / Service 19 11-05-2011 08:49 PM
dashboard led splify UK 0 02-07-2011 05:59 PM
Green LED Dome Light and Underdash LEDs Installed fnkngrv Cosmetic Modifications (Exterior/Interior) 11 08-20-2010 01:38 PM
LED Strip Lights ecmiyake DIY / Maintenance / Service 0 07-22-2010 11:32 PM
Interior LED Ricey Problem xbr3akd0wnx Cosmetic Modifications (Exterior/Interior) 10 05-06-2010 09:50 PM
