#1 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2008 Yaris Liftback (Sprocket) Join Date: Oct 2008
And nothing personal here, but is this your first car? You shouldn't be using your handbrake for anything other than keeping the car in place when its parked or in an emergency when your hydraulic brakes have failed. It is not meant to normally slow or stop the car, and excessive use can make it inoperable if you ever really do need it in an emergency! And I don't think it is abnormal for the handbrake to not disengage the cruise control. I will try it in my Jeep just to confirm that it is the same way. And I don't have a clue as to what you are talking about here. What's a food brake? Do you mean the brake pedal you depress with your foot? If so, are you trying to say that you've injured your foot and cannot push it down far enough to stop the car? If so, then you really shouldn't be driving in that impaired physical condition...
The popularity of racing games and certain unmentionable movies have created a generation of bad drivers.
![]() ![]() Drives: 2006 Yaris HB 5DR Join Date: Oct 2008
Sirs,
my opinion only, I think mescalito2 has brought an interesting point. we love our yaris so much that we should protect it from bad drivers. i would really like sir CTScott to verify this, we can get a signal from the parking brake (hand brake / e-brake) switch and tap this to the clutch switch for M/T or park/neutral switch for A/T to cancel cruise control if engage. you can check it out on the electric wiring diagram of the 2007 manual page 105. |
#4 | |
Pulling the e-brake while driving at cruising speed is ludicrous and is far more likely to result in a serious crash. If the OP has a physical impairment that prohibits he/she from using the brake pedal, he/she should have his/her car properly adapted with hand controls, rather than putting other drivers at risk.
#5 | ||
Cheers! M2
@ CTScott
well said sir, though it is an easy mod, i agree on your point of not using the e-brake to cancel cruise control. +1 also on mod to adapt normal brakes from pedal to hand controls if the drivers is physically impaired to use the foot brake. |
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| Cruise Control on 2010 Canadian Manual | Kaya B. | DIY / Maintenance / Service | 25 | 10-01-2010 03:31 PM |
