![]() Drives: toyota yaris silver 2002 1.0 Join Date: Feb 2011
Another update i love the car nice smooth drive i thought by resetting the ecu would solve it but didnt i unplugged the battery left it off for a bit connected back up speedo starts showing then 2mins later starts going dimmer then goes off any ideas before i send it off to the garage.
#2 | |
That is very strange. If you don't unplug the battery, does it still come on for about 2 minutes when you start the car, or does it remain off until you once again unplug the battery? If the latter is the case, then I would suspect a failure in the drive circuitry for the VFD.
| DIY LED Strip under the door panel | charleschia1986 | DIY / Maintenance / Service | 19 | 11-05-2011 08:49 PM |
| dashboard led | splify | UK | 0 | 02-07-2011 05:59 PM |
| Green LED Dome Light and Underdash LEDs Installed | fnkngrv | Cosmetic Modifications (Exterior/Interior) | 11 | 08-20-2010 01:38 PM |
| LED Strip Lights | ecmiyake | DIY / Maintenance / Service | 0 | 07-22-2010 11:32 PM |
| Interior LED Ricey Problem | xbr3akd0wnx | Cosmetic Modifications (Exterior/Interior) | 10 | 05-06-2010 09:50 PM |
