Old 02-15-2011, 11:57 AM   #1
PumpkinSteve
PumpkinSteve's Avatar
Drives: Yaris SR 1.8
If you put a spacer on the back wheels is there still a decent amount of thread on the wheels studs to screw the nuts on? I don't want my wheels falling off.
PumpkinSteve is offline   Reply With Quote
Old 02-15-2011, 03:02 PM   #2
33OH
Drives: '08 Yaris
Hub spacers go behind the assembly making it not effect your threading at all.
If you use wheel spacers, the largest I would go without extended lugs is 7mm. 5mm if you really want to play it safe. Make sure to torque the lug nuts down to proper specs and to check them every week or so.
Tire rotation: Does TPMS recognize tire position? jcdrotos Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 03-17-2011 02:00 PM
Why does Tirerack reccomend 185/50R15s for seeminlgy ALL of their 15" rims? St_G Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 03-16-2011 06:29 AM
Tire Size and FE question GMKing Fuel Economy Forum 8 09-01-2009 09:20 PM
