u must be lookin in the wrong places. look into the sponsors of the site...particularly micro image. they have tons of stuff.
and about your cat issue, it's illegal to replace the cat before 80k miles...unless it's broken or otherwise not working properly. and it's covered under warranty up to 120k, so why would anyone want to build a cat for it??? jsut cut it off and get a sensor delete kit.
second, research a car before you buy it. if you were so interested in this car you wouldnt care if it had no aftermarket. and if you did research the car before you bought it you'd know there was a small aftermarket for this car. it's an ECO CAR....come on...really??? like anything else, if you want serious power there is potential...but you gotta get smart with it and you gotta do your research. apparently you just want someone to do it for you
there are turbo kits from zage and supercharger kits from blitz. all sorts of OEM parts that will fit most applications for intake like using the bigger corolla throttle body...and injectors. there is aftermarkt support for FMU's, there's an entire section dedicated to power adders. there's another section dedicated to performance upgrades.
