![]() ![]() ![]() ![]() Drives: Yaris LB Turbo Join Date: Aug 2006
I nor anyone here can intelligently answer that question. None of us are Toyota engineers. I can tell you this, engines today are built completely different than 40yrs ago. Fuels, oil viscosities are all 100 times better than the 1970's. Most engines today are aluminum as opposed to cast iron. We have fuel injection & ECU's that control everything. Cant compare 1970's to now.
#2 | |
Even if the block is aluminum, it still has a cast iron/plated cylinder sleeve. Bearing and crankshafts for example are still made basically the same Basically, the only thing made of aluminum are non wear items and critical bearings/mating surfaces are stiil cast iron or steel. Aluminum an other alloys are used prmarily just to save weight, not for better wear properties. Granted, oil is much better but, parts still have to wear in to one extent or another. Capice?
| best synthetic oil and m/t oil?? | doodoo | DIY / Maintenance / Service | 122 | 04-03-2017 08:43 PM |
| Engine noise and Oil Lamp on | bieniman | DIY / Maintenance / Service | 21 | 12-12-2010 11:47 PM |
| Remote Engine Start PT398-33070 | Reeves360 | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 08-26-2009 07:11 PM |
| 90% on short trip. What to do to protect engine? | lh59 | DIY / Maintenance / Service | 22 | 12-17-2008 09:02 AM |
