![]() Drives: toyota yaris Join Date: Feb 2011
CTSCOTT Thats a great idea How did you mount that bar to the strut when you lifted it?I Geuss it goes to a stableiser bar.How did you keep the axel from hitting that bar once you raised it.I Thought if i lifted my yaris i would have to move that bar because the axel would hit it.were you able to keep it alignment help!!!!
#2 | |
I used 1/4" plate steel. The two sides are two separate pieces, and then I used some thick walled pipe to make the spacers to keep the ears on the strut from folding in as I tightened the bolts. I had to grind the flared part off of the bottom of the strut ears to allow the plates to lay right. The axle is not as straight as it was with no lift, but it is no where near rubbing or being at an angle where it would cause quick wear of the CV joints. As for alignment, Crashy is not street-able at the moment, so I wasn't concerned about precise alignment, but I would think that as along as the struts remain in the same plane as they started, that alignment wouldn't be a huge issue. I did have to extend the stabilizers as well. I cut them and re-welded the ends to a longer piece of stock.
CTSCOTT Thanks for the help.dont suppose you have a picture from the front i can see,keep you posted
#4 | |
THIS SCARES ME!! not street-able yet? ctscott are u planning some else with crashy? scott ur the man if u get crashy on the road
Be very scared! I am hoping to eventually get her back on the road, registered as a "kit car". A friend of mine is going through that process with an actual kit car, so I am watching what the DMV requires with his to determine if it is doable.
| Tags |
| height tires |
| The Official *MAD DOG* jokes thread v2 | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 771 | 05-22-2013 11:25 AM |
