Old 02-19-2011, 11:42 AM   #1
jpadua
http://www.viosgen2.com
jpadua's Avatar
Drives: Vios 1.5G
Send a message via Yahoo to jpadua
Ride update: VIOS 08
Still have a long way to go.. but getting there slowly I think :) posting this to share to other vios owners. Vios hard to flush with stance, front liner too shallow. Rear has not camber adjustment. Here are some thing I did to remedy that. Hope this would be useful to other Vios owners.
Added additional -1 degree camber using EZ Shim on rear wheels, so it comes out to about -1.5? (including the natural camber on the drop). Went back to my 5mm spacer, but damn, I felt like I was murdering my tires on the free way... I hate our roads here... I'll try to use a bigger Spring Cushion to lessen the shock play, maybe it would help. Rim to fender now at 5cm, used to be 6cm. Rear dampers at Full Stiff.
Front wheels now at -1 degree camber, also lowered an additional half inch. Rim to fender now at 6cm. Dampers at 5 clicks (1 soft - 8 hard)
Used a heat gun on the liner, it works like a charm!!! Liner rubbing.... GONE!, heated it up, took a wet rag and pushed it in. The water from the wet rag, hardened the plastic in seconds.
Here are some pix:
Smaller space now in between, much... still flush though no poke. Once I find 205 35 18, I can fix that fitment.
Had to saw off a portion of my front lip kit to clear the tires when turning. My finger can barely fit in between.
Now lower about half inch from before. Finally at 0 finger.
Camberlicious! loving the new camber on the rear.
Closer view of the side profile, front wheels still flush.
Thats it for now maybe until I find 205 35 18 for the front, I can lower it some more.
A there is a site for Vios, Belta and Yaris Sedan owners! DIY Articles Etc.
http://www.viosunderground.com
Wheelsearch Classifieds (Beta, need help guys!)
http://www.wheelsearcher.com
jpadua is offline   Reply With Quote
Old 03-02-2011, 09:23 PM   #2
lady-bug
Drives: 2007 yaris sedan base
Here are some pix:
how much was your grille, and body kit seperately
lady-bug is offline   Reply With Quote
Old 05-05-2011, 01:06 AM   #3
matthewai
matthewai's Avatar
Drives: it is kinda stock
hey can i ask you what exhaust this is or is it just a dual tip ? i like the dual look and am going to try to cut and weld a straight pipe with a tip like yours (does anyone know the exhaust piping diameter ? 2 inch?)i like the angled square look too
http://www.etdzmachinery.com/uploadf...6465564446.jpg
Official POLAR WHITE yaris thread wushumasterku Photo-Video-Media Gallery 477 08-27-2023 05:01 AM
