Old 02-20-2011, 01:35 PM   #1
sqcomp
Roadrunner Jr.
sqcomp's Avatar
The issue starts here. We need to keep the substrate flat to get the closest fit to the panel. If the base isn't flat it is VERY difficult to get a build up with all those waves that we see. Also, it's probably better to use chop mat versus glass weave in that area. Chop mat is great for build up, which is what you're trying to do.
― Thomas Paine
Old 02-24-2011, 01:59 AM   #2
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Arrow
It wasn't easy to pull that thing out!
The waves kind of filled in and made a flat surface in the back, the second layer filled in the uneven areas on top, I just added another layer, it's very heavy and solid, I'm going to add another layer or 2 then trim out and glue in the ring for the speaker, any suggestion for aiming the L6s? my feeling is 30-45 degrees at the stick???
This is not easy, I guess after doing it half a dozen times, it gets better!
D.
CLA 250, 4MATIC
