Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 02-21-2011, 01:03 AM   #1
jonimac
jonimac's Avatar
Drives: Yaris Sedan 2010
Send a message via Yahoo to jonimac
Originally Posted by xtremist View Post
mga kayaris, galing kmi sa Lulu kagabi and found some speakers and ampli. can you check if this is ok sa car natin at paano kaya installation nito?
@xtrem, saan mo pala gagamitin yung amp.? It's a 2 channel amp (stereo) or mono (bridged), pwede sya to drive 2 speakers or a sub woofer not more than 200watts.
Connection? still high input (speaker connection) base sa info. nya.
Share ko lang... look for 4 channel amp with sub pre amp out and ask for RMS ratings ng speakers & amplifier not their peak power rating, nakaka ligaw ito mga bro's.
jonimac is offline   Reply With Quote
Old 02-21-2011, 02:27 AM   #2
xtremist
xtremist's Avatar
Drives: yaris Y 2010 A.K.A. "sky"
ah gnun ba, plan ko sana in the future plitan ung stock speaker eh w/ the same size sana, kaya lang no idea ako kung paano pumili ng suitable speajer and ampli pra doon, ampli na kailangan ko e pra lang sa speaker since may active sub nman na tyo.
Ciao !!!
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
xtremist is offline   Reply With Quote
Old 02-21-2011, 03:02 AM   #3
jonimac
jonimac's Avatar
@xtrem, for the meantime hanap ka lang muna ng 4channel amp, also yung may ilne out, mas okay kung filtered for SUB's ang makukuha mo, you'll see the difference talaga. Commonly may high input mga car amps ngayon(bukod sa LINE-IN) so no problem for stock HU, not unless magpapalit ka rin ng HU which would be the IDEAL setup.
Old 02-21-2011, 03:17 AM   #4
xtremist
xtremist's Avatar
hehehe...cge cge, sa ngayon pangarap padin lang yan eh
Ciao !!!
Old 02-21-2011, 03:19 AM   #5
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
tol ako may ampli ako from pinas pa matagal na wala lang un output line for subs pero ok na to drive more power speakers kaso wala din syang high input so cguro dapat magpalit muna ako ng HU ikakabit ko din un like sa plano ni xtremist, try ko kunan ng picture mamaya if makita ko diko na kc alam saan nilagay ni kumander, hehe.. tol tanong lang nakalimutan ko kc ung tawag dun sa splitter ng audio bale kailanagan din nya ng power source then split into 2 or more output line (RCA) para from HU punta sa splitter then punta sa speaker ampli at subwoofer ko.. nakita ko na un sa google pero diko na makita ulit ano tawag dun...
duke_afterdeath is offline   Reply With Quote
Old 02-21-2011, 03:27 AM   #6
jonimac
jonimac's Avatar
@duke, paki google na lang!
Old 02-21-2011, 03:35 AM   #7
duke_afterdeath
sabi kc ni rosco ikaw ang gabay kaya ask ko na lang natamad akong mag google e
Old 02-21-2011, 03:46 AM   #8
rosco
rosco's Avatar
Drives: YaRis ka!--Y?2011
rosco is offline   Reply With Quote
Old 02-21-2011, 06:32 AM   #9
duke_afterdeath
diko makita pa din kung ano tawag di kaya audio booster
Old 02-21-2011, 07:23 AM   #10
syntax
syntax's Avatar
Drives: Yaris Sedan 2010 "shadow"
pre hindi naman kaya "crossover circuit" ang sinasabi mo?
syntax is offline   Reply With Quote
