Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 02-21-2011, 06:32 AM   #1
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
Originally Posted by jonimac View Post
@duke, paki google na lang!
diko makita pa din kung ano tawag di kaya audio booster
duke_afterdeath is offline   Reply With Quote
Old 02-21-2011, 07:23 AM   #2
syntax
syntax's Avatar
Drives: Yaris Sedan 2010 "shadow"
pre hindi naman kaya "crossover circuit" ang sinasabi mo?
syntax is offline   Reply With Quote
Old 02-21-2011, 09:51 AM   #3
duke_afterdeath
di din ako sure basta alam ko from HU audio out (RCA) pasok sya dun sa box na un the labas sya ng 2 or more output para naman pumasok sa 2 or more ampli ung box na un pre need din ng power source.. di ba ang crossover circuit seperating base, midrange at twitter?...
Old 02-21-2011, 11:00 AM   #4
syntax
syntax's Avatar
hohonga kala ko un nga, hindi ba un? ano purpose nun para masplit pa ang audio source?
Old 02-21-2011, 12:08 PM   #5
duke_afterdeath
oo tol para ma split lang sya para if dalawa ampli mo di mahirapan ung HU sa pagbigay ng signal, parang booster splitter yata un
Old 02-21-2011, 03:28 PM   #6
jonimac
jonimac's Avatar
Send a message via Yahoo to jonimac
@duke, in audio world we call it A.D.A (Audio Distribution Amplifier) or AUDIO BUFFER to expand an output more than one. In your case, to just split the line out of your HU (one going to the SUB & the other to another amp - for mid's/hi's) we can simply use this one:
same principle. Use two of this kind, tapos ang problema. Non-Pro nga lang pero I'm sure gagana parehas mga amp mo.
jonimac is offline   Reply With Quote
Old 02-21-2011, 04:15 PM   #7
rosco
rosco's Avatar
Drives: YaRis ka!--Y?2011
Attachment 40081
ginagamit kong splitter to sa TFC connection ko 2sr isa lang nito sa batha
rosco is offline   Reply With Quote
Old 02-22-2011, 02:41 AM   #8
duke_afterdeath
Attachment 40081
ok tol joni so pwede rin palang gamitin itong ganitong type ng splitter meron din nito na RCA cable type splitter, nagdalawang isip ako dito baka kako mahirapan i-drive ng HU ang 2 ampli kaya hanap ko ung splitter na need pa ng power source so hindi pala tnx tol, kabit ko sa friday ung dalawang 4000w na ampli ko
Old 02-21-2011, 03:31 PM   #9
jonimac
jonimac's Avatar
agree ako sayo, crossover works for that.
Old 02-22-2011, 12:57 AM   #10
ubospawis
ubospawis's Avatar
Drives: Flint Mica 2010
Tumpak, passive splitter sya to separate low, mid and high frequency, usually use after the amplifier. Passive meaning no active component like transistor or IC and no need power supply.
ubospawis is offline   Reply With Quote
