![]() ![]() Drives: 2008 5 Speed Sedan Join Date: Jan 2011
wow, thats a fair bit of instructions just to clear DTC's, is it just a jumper wire, straight short? or should you use a resistor?
#2 | |
Literally just a jumper wire is all that is required (i.e. you are shorting the two pins together).
![]() Drives: 2009 toyota yaris Join Date: Apr 2012
G'day CT. Went through the process several times. Problem still not solved. The light would not go out at step 4. Do you have an idea of what that would indicate. Regards Bert
| Tags |
| airbag |
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 08:01 PM |
| Help! Airbag light issue | Astroman | DIY / Maintenance / Service | 24 | 05-18-2019 01:35 PM |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 02:50 AM |
| passenger airbag light problem (NOT stuck on) | ersheff | General Yaris / Vitz Discussion | 3 | 10-12-2010 09:20 AM |
| LED'n it out (warning...big pics) | custom Lftback | Photo-Video-Media Gallery | 9 | 05-24-2010 04:41 AM |
