Old 02-22-2011, 05:01 PM   #1
brg88tx
Drives: 07 Yaris Sedan, Auto
mine completely quit leaking too. coolant level in reservoir in near the full line.
maybe a little splash on the hood is not an indicator the water pump is out. does it just do this periodically to relieve pressure.
brg88tx is offline   Reply With Quote
Old 02-23-2011, 08:13 AM   #2
Vinceb
Drives: 2008 5 Speed Sedan
As far as I know it's a sealed system (except for the reservoir which has an overflow). if it's leaking, it is most likely that a seal has gone and liquid is getting out where it shouldn't. The water pump will probably still work, just not as effectively so it's not 'gone' but your seals are gone and it's probably a lot easier to replace the whole thing rather than just the seals.
if you kept running it with the leaking pump, then you're loosing pressure, loosing coolant and just not working as efficiently.
132,000km (82,000 miles) no water pump issues, no leaks, no spray on the hood.
Vinceb is offline   Reply With Quote
Old 02-24-2011, 12:51 PM   #3
toyo
Drives: toyota
I have a 2003 echo, can noise from the engine come from faulty water pump?
I checked the pulley and it semms a bit 'loose', and my water deposit level goes down pretty fast :s
1st gen FTW
toyo is offline   Reply With Quote
