Old 02-22-2011, 08:27 PM   #1
I have - They are not there. Further more, the pre-09 cluster does not send the CAN bus message to the ECM to request the status of cruise control, like the 09+ does.
Old 02-22-2011, 10:12 PM   #2
CB900F2
Drives: 08 Sedan
Hi Scott.. This is so weird.. If I understand it, even if the instrument cluster did have the needed circuitry, when the user would toggle on the CC, the ECu would not send the data signal to the combination meter to turn on the CC led on the cluster?
Also, did you ever notice this members post from 2006 where he changed out his clusters LED to all blue, and he has the CC indicator!. His user info indicates he owns a 07 Sedan, but he has two threads and one looks like the car is a hatch... This is getting weirder and weirder..
http://www.yarisworld.com/forums/showthread.php?t=2928
http://www.yarisworld.com/forums/sho...&highlight=led
Old 02-22-2011, 10:31 PM   #3
Cruise was a factory option on Sedans prior to 09, so the ECM, which was common to both Sedans and LBs supported it. Both of his threads show a Sedan cluster.
I really expected the ECM to send a message to the cluster, but found that to not be the case. The ECM actually has to be polled for the cruise status, which includes not just the stalk functions, but also the status of the brake cancel, clutch cancel, etc.
Cruise Control Question Ranger SVO General Yaris / Vitz Discussion 7 02-06-2010 11:29 AM
CRUISE CONTROL HELP!! MGargano DIY / Maintenance / Service 1 05-13-2009 08:22 PM
sedan cluster in liftback sanchez DIY / Maintenance / Service 9 02-17-2007 03:37 PM
