Old 02-23-2011, 09:21 AM   #1
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Originally Posted by Focus_Sh1ft View Post
I'm jealous lol. That's exactly what I wanted to do but could never get the O2 skew to work correctly.
Definitely in agreement here, and was going to richen the entire map when the weather warmed up.
I always thought low 15 was safe because in closed loop the mixture would generally run on the leaner side of stoich, and go as lean as 15.4ish frequently. I probably should just be playing it safe rather than trying to squeeze out as much fuel economy as possible...
This is what I was saying about the difference between the Yaris ECU and the Echo ECU. The Echo's is way more forgiving if it doesn't see normal values. The Yaris will freak out and correct them.
Old 02-23-2011, 01:46 PM   #2
Focus_Sh1ft
Focus_Sh1ft's Avatar
Drives: 08 Yaris Turbo; 06 tC Turbo
I'm just curious as to why you think this? Theoretically, if you're manipulating the AFR sensor's voltage, it can't really correct itself since it's the main method of fueling feedback (and therefore will think that everything is okay).
However, I definitely think the ECU might see continuous low voltage at the AFR sensor and throw a code. More importantly though, it probably would throw the engine into open loop. No one has really tested this method of tuning on the Yaris yet, so I'm just speculating.
Could this be where the Yaris and Echo ECUs differ?
Focus_Sh1ft is offline   Reply With Quote
Aem fic 1.5ty Forced Induction Forum 17 08-16-2015 07:22 PM
aem fic $280 1.5ty Items for Sale by private party 1 10-22-2010 11:06 AM
Aem fic 1.5ty Items for Sale by private party 24 10-05-2010 03:59 PM
AEM FIC works in Yaris......Sort of cdydjded Performance Modifications 32 12-06-2009 01:58 AM
AEM FIC works perfectly cdydjded Performance Modifications 58 08-03-2009 06:20 AM
