![]() Drives: Blazing Blue 2007 3dr HB 5MT Join Date: Jul 2009
Is the 60k miles service worth the $400 at the dealer?
I was just wondering if anyone had gone to the dealer for the 60k mile service. I haven't had the time to look in the manual to see what is included so I just wanted to get some opinions.
Thanks |
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
There is no additional maintenance requirements at 60K other than oil change, oil filter change. Look at the air filter, cabin air filter and consider if a tire rotation is necessary.
Also, if you haven't already, consider changing the manual transmission gear oil. Use Redline MT-90, which you can buy from JEGS or other online retailers, or whatever Amsoil makes. |
![]() ![]() Drives: 2008 Yaris Hatch Back Join Date: Feb 2011
You should ask the Dealer what they are going to do for the $400.
Absolutly
Fact is, if you have been maintaining your car properly yourself for the last 60k miles, there is nothing to do to it that would cost anywhere near a total of $400 worth of scheduled maintenance |
#5 | |
![]() ![]() Drives: 2008 5 Speed Sedan Join Date: Jan 2011
The more major services would be 64k and 128k (40k and 80k miles) which according to Toyota is the Transmission fluid and the coolant (at the higher interval). I'm not sure what they do in the US, but here in Canada that servicing includes: -Oil change & filter -remove wheels and inspect brakes (they only look, they don't do anything) -check and top up all fluids -check belts -check battery -check air filter -inspect valve clearance (only listening to it) -rotate tires if required but costs extra -and a few other things checked. basically it's worthless if you're out of warranty because they're only looking for things that could be damaged or need replacing to make more money off you (worthless, assuming you can do your own work and take care of your own car). I just had one done for my 128,000km and they wanted $50 to adjust the rear brakes, $50 to remove rust and lube front slider pin and recomended I replace the front rotors and pads for a grand total of $450 |
Its so funny that they remove the wheels to inspect the brakes anyway, but still want to charge you extra for swapping the tires and "rotate" them.
#7 | |
$400.00 is more than I've spent on maintenance in nearly three years of ownership. I'm using synthetic oil (bought on sale at 50% off) with OEM oil filters (bought by the case from eBay, 50% of dealer cost after shipping) plus a K&N drop-in air filter (pay once on sale at 150% the cost of one OEM disposible filter, clean annually for life of the car). Plus, 30 minutes in my driveway with simple hand tools is faster than any stealership could get me in and out and at my convenience. Do it yourself = WIN-WIN!
For $400 you are basically getting an expensive oil change.
^ That's about it.
Modded Moderator
Yup, read the manual. No real service really needed until 100k.
When you take your car to my dealer for that they inspect the enire car and inform you in the direst possible tone of voice that your car needs $3000 worth of repairs IMMEDIATELY!
#12 | |
![]() ![]() Drives: 07 Yaris Sedan Join Date: Jan 2009
At 60,000 miles (96,000km) it's essentially a huge inspect (look for problems) list:
--Looking for problems-- Inspect air filter element Inspect ball joints Inspect brake calipers and wheel cylinders Inspect brake lines and hoses Inspect brake linings/drums and brake pads/discs Inspect brake pad/shoe thickness Inspect chassis nuts and bolts for looseness or damage Inspect coolant, brake & washer fluid levels Inspect drive belt for damage, adjust tension if required Inspect drive shaft boots Inspect dust covers Inspect engine coolant Inspect engine valve clearance (auditably) Inspect exhaust pipes and mountings Inspect fuel lines and connections, fuel tank band and fuel tank vapor vent system hoses Inspect fuel tank cap gasket Inspect lights, horn & wipers for proper function Inspect radiator, condenser and/or intercooler Inspect shock absorbers for looseness, damage, or leakage Inspect steering gear box Inspect steering linkage and boots Inspect tires & adjust pressure as required, including spare Inspect transmission fluid or oil Lubricate locks, latches, and hinges Rotate tires = Dealer cost: $210? or $0 DIY cost --Actual replacement-- Replace cabin air filter ($10 DIY/$30 dealer) Replace engine oil and oil filter ($20 DIY/$40 dealer) Replace transmission fluid ($40 DIY/$120 dealer) = $190 dealer replacement costs or $70 DIY cost |
| 15K service @ dealer... WTF? | lawnmowerdeth | DIY / Maintenance / Service | 15 | 08-13-2010 10:49 AM |
| 60K Service by Dealer or Independent Mechanic? | tomato | General Yaris / Vitz Discussion | 33 | 01-19-2010 07:42 PM |
| 5K miles and no service light | regal | DIY / Maintenance / Service | 10 | 07-15-2009 10:05 AM |
| Dumb newb question: service x months or y miles | ejaf | DIY / Maintenance / Service | 6 | 06-25-2009 11:34 AM |
| is the toyota extra care vehicle service agreement worth it? | waylandchin | New YARIS Purchase Forum | 33 | 04-19-2007 11:46 PM |
